-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Help! need fast rebuild advice (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/97059-help-need-fast-rebuild-advice.html)
BenI 02-05-2003 12:58 PM
I just found out my 2.0L case is shot. I have another early 1.7L case (heads have the small pushrod tubes) and I'm wondering if I can use that. The machinist said I need "30 under rod bearings for the 2.0L crank" and "10 under" main bearings. My questions are:
Can I use the 1.7L case for a 2.0L rebuild?
Is this crank too far gone or can I try using the 30 under bearings?
Thank you very much!
Ben
JWest 02-05-2003 02:22 PM
Yes, the 1.7 case is fine to use. There are no differences between the 914 cases except for the deletion of a bypass valve in '73 I think, and I don't there is much difference whether you have it or not.
Mike D. 02-05-2003 02:43 PM
I have a 1.7 case if you need one. Let me know, I make you a great deal (plus shipping) just to get it out of my garage.
-Mike D.
BenI 02-05-2003 03:32 PM
Thanks a lot Mike. I have a 1.7 that has never been rebuilt before so I'm going to have the case checked out and hope it passes the test.
red-beard 02-05-2003 07:59 PM
Early 1.7's don't have the oil windage tray. But you can transfer it along with everything else from the 2.0.
James
PS: And if you're _REAL_ nice to Mike95125's girlfriend, she might clean it for you....
:p
mike95125 02-05-2003 11:45 PM
Hey, I dont farm out my honey. She is my grease monkey;)
