Help! need fast rebuild advice
I just found out my 2.0L case is shot. I have another early 1.7L case (heads have the small pushrod tubes) and I'm wondering if I can use that. The machinist said I need "30 under rod bearings for the 2.0L crank" and "10 under" main bearings. My questions are:
Can I use the 1.7L case for a 2.0L rebuild?
Is this crank too far gone or can I try using the 30 under bearings?
Thank you very much!
Ben
Old 02-05-2003, 12:58 PM
JWest's Avatar
Yes, the 1.7 case is fine to use. There are no differences between the 914 cases except for the deletion of a bypass valve in '73 I think, and I don't there is much difference whether you have it or not.
James
JWest Engineering
Old 02-05-2003, 02:22 PM
I have a 1.7 case if you need one. Let me know, I make you a great deal (plus shipping) just to get it out of my garage.
-Mike D.
-Mike D.
'74 914-6
'94 968
Old 02-05-2003, 02:43 PM
Thanks a lot Mike. I have a 1.7 that has never been rebuilt before so I'm going to have the case checked out and hope it passes the test.
Old 02-05-2003, 03:32 PM
canna change law physics
red-beard's Avatar
Early 1.7's don't have the oil windage tray. But you can transfer it along with everything else from the 2.0.
James
PS: And if you're _REAL_ nice to Mike95125's girlfriend, she might clean it for you....
James
Red-beard for President, 2020
Old 02-05-2003, 07:59 PM
mike95125's Avatar
Hey, I dont farm out my honey. She is my grease monkey
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 02-05-2003, 11:45 PM
