vacume advance
My 914 came with a larger vacume advance. it has what looks like two nipples for vacume hoses with the one facing the distributer closed off and the one facing away from the distrubuter going to the throttle body. Is this the right vacume advance? should one be blocked off like that? and where can i get a new/rerbuilt one... i dont see one on PP. i might just be ignorant though
beautiful 74 1.8L pain in the BUTT! you can write me directly at CHAMP914@hotmail.com [just no signing me up for any junk mail ![]() |
Eric; I also have a '74 1.8l stock engine. My vacuum advance is just the opposite of yours ie: the nipple facing the dist. has a vacuum hose to the throttle body, while the nipple facing away from the dist. is open. It works for me!
the nipple on mine is not open to the air... it has a cap on it which does not seem right. Also the one i have is bad, meaning it does not hold a vacum when tested so i will need a new one
.... ok and i just checked and on mine the nipple on the distributer side is the one that is capped of while the one on the other side went to the previous side. so i need a new V. Advance any ideas?
Hmmm, IIRC the side of the vacuum can that faces the dizzy is the vacuum retard side. The other side is the vacuum advance side.
Blocking one side seems not to be a good idea. Check on the Tech pages for a diagram that shows how the hoses should be hooked up – I think I have seen something for a 1.8l Patrick
'74 Porsche 914 2.0l '90 VW Vanagon 1.7l Diesel |
Administrator
The fittings on the distributor get hooked to the fittings on the throttle body. If there is only one fitting on the throttle body, it goes to the retard (pointing at the distributor body) fitting on the distributor.
They used the same distributor dashpot for the 74+ cars that didn't have vacuum advance (cheaper that way), they just didn't drill the throttle body for the advance fitting. If you do not have vacuum advance, you should leave that fitting on the distributor open to air. Or do what the factory (or dealer?) did--put a hose on it and run it somewhere out of sight so it doesn't look odd. I have been told that capping the advance fitting messes up the operation of the vacuum retard. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
I've got a spare dizzy, I'll play with it and see what the effects are. |
~ DD
Does Pelican Parts sell these? I cant find them in your catalog anywhere. Mine is bad and cannot hold a vacume. If you guys dont carry them who would... thanks
Administrator
Just because it isn't in the catalog....
Call up and ask. Steve is definitely a 914 guy, he should be able to find the bits in the internal lists. --DD
