kpfoten's Avatar
Question Headlight Question
Hello,
Got some gremlins in my headlight system... When I turn the headlights on, only the left works. When I turn the brights on, the right one will light up, but the left one wont... Arrgh!
The headlamps seem to be fine (I switched them to make sure)
The fuses _seem_ good -- I checked them at the fuse box with a multimeter.
Any help would be appreciated.
Thanks,
Kris
77 911S
Kris - '77 911S
Old 02-17-2003, 07:10 PM
Possible headlight relay on the backside of the fuse panel. (underdash) All kinds of spooky things happen when one of them dern relays acts up!
Don
Don Kiepert
'73 Big Bore
'02 GTI 1.8T
Race a Porsche - There's more to life than left turns!
Old 02-17-2003, 07:23 PM
RustyWa's Avatar
My guess would be a ground problem somewhere. Old timer once told me when I was much younger that 80% of electrical problems are bad grounds.
Eric
'75 914 2.0L - Sold!
Old 02-17-2003, 07:25 PM
Peter_Hinkle's Avatar
Send a message via AIM to Peter_Hinkle
Kris, if you didn't actually replace the fuses, i would give it a shot if the relay turns out to be good. i have seen 914 fuses appear to be good and even check good only to turn out to be bad many times. Good luck! hth peter
Peter Hinkle
drumvudu@earthlink.net
http://home.earthlink.net/~porsche914
1974 Saturn Yellow 914/4 1.8/w BigBore/Webers/MSD
1988 944 Black on Black w/phone dials
Old 02-17-2003, 07:48 PM
philinjax's Avatar
Kris,
You either have one or more blown fuses, corroded fuse contacts or headlight elements burned out. Your control circuitry is okey.
Phil
Old 02-18-2003, 05:23 AM
914 Geek
Time to tear the headlight covers off so you can check if you're getting +12V on the lowbeam and highbeam connectors at the appropriate time... That will also let you check your ground as well.
--DD
Old 02-18-2003, 07:49 AM
kpfoten's Avatar
Yep. Stupidly simple! Just had to remove the fuses, clean them off, and reinstall.. Voila!
Thanks for the responses!
Kris - '77 911S
Old 02-18-2003, 01:40 PM
