-   -   Speed/Reference sensor test (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1000708-speed-reference-sensor-test.html)
mikseymono 06-27-2018 10:01 AM
Hi team!
First post...from the other side of the pond.....
Trying to work out why car seems to hit wall at 4000rpm...almost like a limiter...have read many several thread on this subject and have checked quite a few parts as per Clarks. Think it could be the reference sensors.
Just on the "jump" tach bit when you start the car.....I understand that if this jumps when you start the car say 1/8th inch the sensors are likely to be OK. Things is when I start the engine and it starts up mine in neutral the tach jumps to about 1200rpm...so about 2 inches.........is this what they mean by starting...as in turn the engine on...or just turn the key to on and this is when the needles come to life on the dash.
Sorry for the noob question....
Cheers,
M
DannoXYZ 06-27-2018 01:45 PM
Just key to ON, don't start engine.
Measure impedance of sensors. Better to plot their output waveforms with oscilloscope.
When you hit 4000rpm, is it smooth up to that point? Then abrupt stop and holds at 4000rpm?
Pauld_94S2 06-27-2018 03:21 PM
Testing:
https://www.youtube.com/watch?v=zeFOOcLSk60&t=5s
Gapping:
https://www.youtube.com/watch?v=-MbghejYiqk
mikseymono 06-27-2018 11:30 PM
Thanks for this...well....no jump at all with key on..so I suppose that is positive in a negative way!
My car is a 924S 1988.
It is smooth up to 4000 rpm but really quite slow....no abrupt stop but really sounds like it might explode. Feels like it has hit the rev limit.
Here is my UK thread https://porsche924.co.uk/forum/viewtopic.php?f=46&t=31276
Quite detailed and have tested quite a few areas with your excellent Clarks website.
Will check the sensors from the DME this morning as per Pauld924s advice.
Thanks,
M
mikseymono 06-28-2018 04:28 AM
So, without sounding too thick...just turn the engine to ON, but not start it, and the tacho needle should jump. Yes? If this is right....mine doesn't........
M
mikseymono 06-28-2018 04:31 AM
Originally Posted by Pauld_94S2 (Post 10088145)
Thanks for this...really good informative videos.
Just trying to get to the bottom of why my 924S 1988 seems to hit rev limiter and sounds really strained at 4000. It is smooth to get there but not fast at all.
This is my UK thread..https://porsche924.co.uk/forum/viewtopic.php?f=46&t=31276
Thought it was fuel related and now more inclined towards senors....
Cheers,
M
mikseymono 06-28-2018 06:00 AM
So tested as per the vid...and all good!
However, as posted by DannoXYZ the Tacho will not jump when you turn it to on. So what does this mean please?
Thanks,
M
Pauld_94S2 06-28-2018 07:19 AM
You need to crank the engine.
If the flywheel isn't turning, then there won't be any sensor pulses.
mikseymono 06-28-2018 07:24 AM
Well...a bit confused now..as Danno said orherwise! Engine running or just to on......
DannoXYZ 06-28-2018 11:04 PM
sorry, yes, need to crank.
If no tiny little bounces, sensors aren't sending proper signal to DME.
Follow Clark's Garage guide to:
1. measure impedance of sensors
2. space sensor from flywheel properly.
mikseymono 06-28-2018 11:46 PM
no worries danno...when I crank engine it goes to about 1200rpm...not tiny little bounces as you say. Already measured impedance, at the plugs as well as DME, now just need to check spacing. Running out of ideas though...
Anyone have any clues re my revs not going more than 4000rpm..as per my thread?
Thanks,
M
mikseymono 06-29-2018 04:46 AM
OK..well, just cant get the sensors off! Have removed bolts but feel iImay break the sensors. Have tried wiggling/pulling etc. Is there a special tool /technique please?
Thanks,
M
944 Ecology 06-29-2018 05:05 AM
The special technique is to have a couple of sensors nearby, as the likelihood of breaking sensors that have been in place for at least 30 years is quite high.
My success rate (for sensors in engines/drivetrains that had been removed as a whole from chassis) is around 50 percent.
If you don't break the bracket for the sensors, it will help to open up the hole into which they fit... there is no advantage to having the sensor as a friction fit.
mikseymono 06-29-2018 05:10 AM
Thanks for reply.....guess I really need to find out if the sensors are defective first before playing parts Lotto.............just don't have an oscilloscope...
944 Ecology 06-29-2018 05:12 AM
https://www.picotech.com/products/oscilloscope
In the giant scheme of things, cheaper than two sensors and a bracket.
mikseymono 07-04-2018 12:24 AM
Just a question please:
If I have bad speed and reference sensors I thought the car would not start. Is it possible for the car to start with faulty sensors or sensor?
It is because of this thread http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/416709-help-me-diagnose-poor-idle-rough-running-low-power-engine.html
Other than the 'pop' he mentions it is the same........just don't have an Oscilloscope to test...
Thanks,
M
DannoXYZ 07-04-2018 08:21 PM
Without oscilloscope, you can at least measure impedance of sensors. Will at least 100% confirm they are bad if out-of-range.
mikseymono 07-17-2018 03:52 AM
OK...so..managed to get sensors out...not too bad.....the one nearest the bulk head in hole 'D' was badly eroded on the top as in it was rubbing against metal. I gaped new sensor as per Clarks. I stuck an 8mm thick cut up credit card to gap them. I cranked the engine. Straight away the tacho jumped up to around 4500 on start with no foot on accelaration...first time I have ever seen that...exciting, engine felt much more alive.....however there was this high pitched metal grinding whine. Sure enough I checked new sensor and the new one was eroded on the top as well. It turns out the aftermarket one is slightly...maybe...1mm longer than the OEM.
There does not seem to be the amount of play on the up down motion of the bracket on mine against this instruction vid https://www.youtube.com/watch?v=-MbghejYiqk
I have now put the old one back on as I have no more!
Convinced it is the speed sensor that is the problem. So question is, how hard is it to gap and if the sensor was scratched eroded would this make the difference? Was a bit adverse paying top whack for OEM Bosch sensor so bought these instead https://www.ebay.co.uk/itm/CRANKSHAFT-S ... 2749.l2649
Thoughts please.
Thanks,
M
mikseymono 07-20-2018 04:04 AM
Hello!
So, it seems I don't have the 0.3mm washer that goes between the sensor and the bracket as per the PET diagram. No 29. Is this really going to make any difference?http://forums.pelicanparts.com/uploa...1532084509.jpg
http://forums.pelicanparts.com/uploa...1532084559.jpg
Thanks.
M
944 Ecology 07-20-2018 05:20 AM
If your bracket has the sleeve (#28), then it should have the spacer (#29) in order to maintain the relative relationship between the two sensors.
mikseymono 07-20-2018 06:31 AM
Thanks George...sadly mine does not have the in built space for the bracket.
Just asking if the 0.3mm spacer is critical to it sitting square to the teeth of the flywheel?
Thanks,
M
Jfrahm 07-20-2018 06:36 AM
There are cheap DMMs these days for $20 and less that will measure Hz and AC voltage from sensors like these. Maybe the ZT102 for $16 'merican, that looks like a good choice.
I'm thinking it's a spark problem in your case but you might be able to inductively measure that while driving. Or maybe first try to observe the DC pulse frequency at the coil while revving/driving.
-Joel.
mikseymono 08-02-2018 10:19 AM
Have just found out the speed sensor female plug is intermittent. This is the plug that goes back to the DME (ECU) It is the wires just behind the plug....certain bending produces no tach bounce/start and another way starts straight away......probably my fault as I have pulled these apart 20 times or more in setting various sensor gap combos....
So, finally, a problem that I can solve....HOORAY. :clap:
So, what are the options please to repair this lead.....not much room or length in the lead to splice much.
Would this have an impact on my rev issue or am I being over optimistic?! :food:
M
944 Ecology 08-02-2018 11:50 AM
https://www.lindseyracing.com/LR/Porsche/LR-944-HAR-REF.html
curtisr 08-05-2018 07:16 AM
The part number for the figure 8 washer (should you not know) is 951 101 325 00. You can get them here and here among others.
And I'm sure you've heard this before: avoid the FAE sensors (should you need them). I tried them without success and had to borrow some Bosch ones from a friend. Bingo! Car started.
mikseymono 08-18-2018 01:52 AM
So...my "B" reference sensor is definitley intermittent. I need to unclip it/bend wires to get it started/tach bounce every now and then. I feel that I will change the sensor first, as I have a spare, before I try and splice in new cable.
The question is though, once started I then pulled the B reference sensors apart and the car still ran....is this normal?
Thanks,
M
mikseymono 08-23-2018 06:58 AM
Ok...so its been a few days since my last post.....
I have managed to get the instrument panel battery light up and working now and this has definately made things better. It can now pull towards 5000 rpm There was no earth strap on my alternator just the exciter small blue wire and the heavier gauge one to the starter. Would this make a massive difference?
However, it is still pretty pedestrian......I have checked and changed the reference sensor twice now...but as I have nothing to compare it to I don't know if this is good or not. It all checks out as per Clarks....but it is definately not right.
For the moment the car runs and gets to speed eventually which around these parts is generally an earth shattering 80kph......
I fear I may have to visit a local Porsche mechanic as I seem to have exhausted all sensible possibilities....but open to other suggestions.....
Thanks,
944 Ecology 08-23-2018 09:11 AM
Thanks,
M
Yes, once the ECU has figured out where TDC is, it simply counts the teeth on the starter ring gear to know where it is from then on. Of course, you still need both sensors to get the car started.
mikseymono 08-31-2018 08:56 AM
Ok...so here it is.....my 0-60mph time.......don't always rag it but this was basically WOT from standstill up to 60 mph....about 11 seconds!!...3rd gear pulls quite well but first and second seem really strained. It is certainly alot better since I put in the battery dash bulb and can rev it up to around 5300rpm.....but no red line...and I tried......still very slow...according to by power curve diagram 60 mph should be achieved by just going into third.
https://youtu.be/uDEjcsI3nSs
So...all comments welcome!
Thanks,
Michael
DannoXYZ 08-31-2018 11:02 AM
No need to splice in cable. Just snip off the connector and install new one. I listed all parts needed to replace just about every connector in harness here: DIY Harness Connectors
