I needed to remove the front bumper on my 1987 924S. Part of removing it is to disconnect the turn signals which are housed in the bumper. I noticed that the rubber boots around the front turn signal sockets are deteriorating.
![]() Does anyone know where I can buy new boots? If the boots are no longer available, what did you do to cover the socket to keep it dry?
1987 924S daily driver even in the snows of Idaho Yes I am scraping the ice off the inside of the windshield. |
Frankly my dear....
Hi, these are no longer available from Porsche, but over here in Europe there is company that has re-manufactured them. here is a link...might help?
https://partworks.de/partworks/en/15323/1x-rubber-grommet-plug-for-porsche-924-944-turn-signal-headlight-cover-cap?c=986
Porsche - accept no substitute Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project Black 1987 944S - Gone but not forgotten Metallic Black 1980 924 - Those were the days.... Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began! |
There is a VW part that is similar and functionally the same and pretty easy to get.
171957911 is the part number
1984 944 Zermatt Silver 1987 951 Flamingo Metallic |
kind of joking but if you buy a pair of heavy rubber gloves you can cut the fingers off and get 10 of them .. then use tie wraps and some sealant maybe.. you never see them and they keep water out right?
Did you hear about the guy with 5 penises? - His pants fit like a glove. |
Tags |
electronics , turn signal |
