-   -   Trans Coupler Threads Stripped (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1008038-trans-coupler-threads-stripped.html)
Brozoar 09-17-2018 07:11 AM
Well, I learned a valuable lesson; always get both transmission coupler bolts started before doing final tightening on either of them. I tightened down the front bolt before turning the engine over to do the rear, and it must have been far enough off that I sheared the threads off on the rear bolt against the sides of the groove. Can't really think of another explanation.
https://imagizer.imageshack.com/v2/6...923/swUqzG.jpg
What are the chances the threads in the coupler are still good? I *really* don't want to have to drop the trans again. I'm a slow worker. Any way I can test them without risking getting a new bolt stuck?
kdjones2000 09-17-2018 07:32 AM
Threads will be fine. Get a new bolt and get them both started before tightening, like you mentioned.
plyhammer 09-17-2018 08:11 AM
Yep done this a few times. Coupler is fine
Brozoar 09-17-2018 09:10 AM
It's good to hear I'm not the only one to commit this gaffe. Thanks, guys!
DannoXYZ 09-17-2018 09:06 PM
Yeah, get the alignment perfect before doing rear bolt.
With the front bolt tightened, you can actually pry on square block to shift driveshaft fore-aft so hole of 2nd bolt is perfectly clear. I use a motorcycle tyre lever.
campbelljj 09-20-2018 04:27 AM
Also put that coupler in a vice or something else to secure and clean the threads with tap.
pfarah 09-20-2018 01:59 PM
I believe the manual recommends to replace these bolts as they one-time use (micro-encapsulated).
