Self-Proclaimed Newb
Brozoar's Avatar
Send a message via Skype™ to Brozoar
Trans Coupler Threads Stripped
Well, I learned a valuable lesson; always get both transmission coupler bolts started before doing final tightening on either of them. I tightened down the front bolt before turning the engine over to do the rear, and it must have been far enough off that I sheared the threads off on the rear bolt against the sides of the groove. Can't really think of another explanation.
What are the chances the threads in the coupler are still good? I *really* don't want to have to drop the trans again. I'm a slow worker. Any way I can test them without risking getting a new bolt stuck?
Current: 1986 944 Turbo - Sapphire
Past: 1983 944NA - Black (RIP)
1985.5 944NA - Guards Red (in purgatory)
1985.0 944NA - Maraschino Red (traded for a Volvo 244 )
Old 09-17-2018, 08:11 AM
In the Fires of Hell.....
kdjones2000's Avatar
Threads will be fine. Get a new bolt and get them both started before tightening, like you mentioned.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 09-17-2018, 08:32 AM
West Central Ohio 45380
plyhammer's Avatar
Yep done this a few times. Coupler is fine
www.plyhammersparts.com
Old 09-17-2018, 09:11 AM
Brozoar's Avatar
It's good to hear I'm not the only one to commit this gaffe. Thanks, guys!
Old 09-17-2018, 10:10 AM
Yeah, get the alignment perfect before doing rear bolt.
With the front bolt tightened, you can actually pry on square block to shift driveshaft fore-aft so hole of 2nd bolt is perfectly clear. I use a motorcycle tyre lever.
Old 09-17-2018, 10:06 PM
campbelljj's Avatar
Also put that coupler in a vice or something else to secure and clean the threads with tap.
Old 09-20-2018, 05:27 AM
Patrick
pfarah's Avatar
I believe the manual recommends to replace these bolts as they one-time use (micro-encapsulated).
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 09-20-2018, 02:59 PM
