Driver
Do I need to remove the races?
Hello all,
I am putting new inner and outer wheel bearings in my front wheels. I have both bearings out, the races are still in the hub. Is there any reason they have to come out, or can I just put the new bearings in after packing them with grease? I mean, I will just have to turn around and put the races right back in right? I feel as if I am missing something lol. The bearings are the roller bearings, and the races are the solid, round pieces of steel. I have the outer bearing (fell out when I took the wheel off). I have removed the dust seals and the inner bearing was underneath that, I THINK I have all of the bearings I should have. GHEN
'87 944 |
944 S2
Didn’t the new bearings come with new races?
I would replace both. The races should be press fit. |
Go to one of the auto parts stores that loan tools and get the installation tool. They come out pretty easy with a punch and install easy with the tool no reason not to change them. As stated they should be included with the new bearings
89 930 Cab Black 11 Cayenne |
Never heard of anyone just using half a new bearing, why would you do that other than laziness. The races are part of the bearing and they generally wear together. If you fit new ball bearings into worn races, it’s likely the new bearings won’t last too long.
Get a brass punch and work the race out carefully so as not to make contact with the alloy hub with the punch. There are cut-outs on the hub to provide access for a punch, takes a couple of minutes for each race.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. Last edited by 9FF; 09-23-2018 at 12:42 PM.. |
Driver
To tell the entire story, I don't have the new bearings yet, I figured I would see what came out of the hubs and buy what I needed. I didn't know new races came with the bearings...glad I asked the question.
Thanks for all of the kind replies, massively helpful! GHEN
'87 944 |
it is best to heat up the hub in an oven to 225-250 degrees F to remove and install the outer races. you should still use a press to be sure the races are bottomed in the hub and it helps to chill the races in the freezer. with the temp differential, they pretty much drop in.
Brass usually works if the hubs have been heated first as thomasryan suggests, you can use a steel punch, just be careful to not score the hubs. Line up the punch in the cutout and tap it with a heavy mallet, firmly securing the hub in a vice really helps. Work both sides evenly through the respective cutout and the race should shimmy out.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
Driver
I re-faced and re-formed my brass punch and went back at it, but didn't heat again. I wonder if I throw it in the oven will my kitchen smell like old grease? Mrs. GHEN wouldn't like that. GHEN
'87 944 |
Tired Member
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
"I wonder if I throw it in the oven will my kitchen smell like old grease? Mrs. GHEN wouldn't like that."
Wouldn't have the 'nads to try that one...try MAP again It will come out eventually!
Bruce P. 2011 Cayman Base, LSD, Sport Chrono. 1988 951 totaled and missed ![]() "You're the best I ever had" --JJ Cale |
