Can you post pictures? Even if you are using the lower mark the OT mark will still line up perfectly...
I tried posting pictures but doesn't work, can someone tell me how?
Wondering if the belt is not right honestly but that's the second one from the dealership, and I haven't seen anyone say anything belt related... cause I'm literally off by half a tooth, and that can't be, even if I messed up a sequence it should at least throw me off by a tooth..
Are you using a gates belt? I've encountered a problem before with gates, doesn't line up.
Yes, porsche gave me a gates belt, I do have the first belt I got from napa that I could try on again..
What belt did you use, maybe I'll give that a try
You found the problem. Contitech.
Nooo wayyyy that's the problem whattt!!!
Wich belt should I get ?
Contitech, but doesn't the Contitech come with different pulleys than the stock ones on, and isn't their belt fitted for their upgraded pulleys
Can you send me a link to wich belt I need to specifically get
It's OEM. WFT more could you ask for? What year do you have?
1984 944 na
I mean I figured the dealership would at least give me the right one
Go contitech. Dealer doesn't stock parts for 30 year old cars, they supply (if at all) with aftermarket.
Edit. They do stock OEM parts, but we are concerned with a rubber belt. |
Will do that, can you please send me a link to the exact one I need
Just cause I want to make sure I don't need the Contitech full kit, and can just use the belt on my stock pulley, cause I heard that could make a difference also, you know better
This one, https://www.pelicanparts.com/catalog/SuperCat/944M/POR_944M_BASFLT_pg4.htm#item13
Sorry, it's this one Part #: 944-105-157-04-M21 |
| All times are GMT -8. The time now is 01:05 PM. |
