chapstic2001's Avatar
Send a message via AIM to chapstic2001
Brain Picking for Brake Trouble Shooting
I need some help. I was under my car over the weekend finally getting some work done. One task was to replace the rear break pads, the garage told me they were low. The drivers side pads looked fine, hardly any wear. The passanger inner pad looked the same. The outter was under a quarter left.
What would cause this? How can I fix it? I had the break fluid flushed and repalced and only drive it 50 miles or so. So I can't fault the garage for it. Any suggestions?
'08 BMW e90 335i 6MT stock [aka 'take two']
'12 Dodge Durango [family hauler]
'86 951 (K&N Cone, Welt Chips, Tial, Zeitronix, P&P O-ring PH Head, WFHG, AFPR) [in storage]
Old 03-03-2003, 11:39 AM
Scott R's Avatar
That would be a dragging caliper. You can get a rebuild kit for the caliper. Blow the pistons out and clean up the cylinders, then replace the seals. That should take care of it.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-03-2003, 01:03 PM
suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
yes.. do what scott said... Harumph!!
My car is naughty
Old 03-03-2003, 01:15 PM
Who carries the rebuild kit? Would I need to bleed the brakes afterwards?
Old 03-03-2003, 01:58 PM
Scott R's Avatar
Try Jason over at Paragon Products. I know that Pelican does not stock them. But I foud kits at Paragon.
And yes you will need to bleed, the best way to do this is to use a tool called a "line lock" to clamp the rubber hose off during removal, but you will need to bleed the system afterwards reguardless.
Another more costly avenue would be to aquire a brand new or rebuilt caliper assy.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-03-2003, 02:13 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Or a pair of visegrips
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 03-03-2003, 02:59 PM
If the outer pad is worn then probably the sliding part of the caliper is stuck, pull the pads out and try and push the caliper frame. If it's stuck, spray some penetrating oil in the sliders and move it (usually with a hammer) untill it's free. Clean all the oil off and replace the pads.
No parts required.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 03-03-2003, 04:02 PM
Let's go shooting.
Dark Skies's Avatar
No parts required.
BUT be sure to cover the caliper pistons because if you get any penetrating oil on the rubber seals it buggers them up and you'll get leaks. If you want to see just how quick penetrating oil buggers up rubber blow up a balloon (or condom if you want to spice things up) and spray a dab on - it'll pop in about two minutes.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 03-03-2003, 05:39 PM
coupe's Avatar
Chapstick 2001
Mr. Chapstic, I had the same troube, and ordered a re-built calipper from www.944online.com. After fitting it, the trouble was still there, if you listen while you drive, it may even make a whinning sound.
It happened to have been the bearing hub and spindle that were both wornout, this caused half of the bearing race to float, pushing the brake rotor to the brake caliper causing the sound and the premature wear of the brake pad.
Look closely at this picture.
Good luck
coupe
http://www.p-caronline.com/directory/coupe
Porsche 944 Turbo, 1986
Fiat Coupe 20v Turbo, 1997
Old 03-04-2003, 02:38 AM
Coupe, I have noticed that the when breaking it will be very rough. Actually sounding like the metal on metal. Like a very worn brake contacting with the rotor. What did you replace other than the caliper? How are your brakes working now?
Old 03-04-2003, 07:49 AM
coupe's Avatar
My brakes are fine now, but I still have the old rubber hoses, not steel braided lines...I have aftermarket brake pads, and my car doesnt have ABS..
I replaced the brake pads,caliper (mistake made by workshop ) wheel bearing and hub and spindle .
I need to compare it with another 944, to be sure how good my brakes are.
coupe
Old 03-04-2003, 07:58 AM
Bay Area Patriot
TheStig's Avatar
warped rotors can also lead to abnormal wear. might as well rebuild and replace while down there. Oh and don't forget those bearings!!!
Andy
1987 928 S4 - 3" Single Exhaust after cats
1999 Mercedes C280 Sport Package
2003 Mercedes ML350
Old 03-04-2003, 09:26 AM
I am going to try the rebuild first off. Hopefully it is not the hub and spindle. While stumbling around, I found a great link on the rebuild process. I thought I would share.
http://vista.pca.org/sch/tech_articles/caliper_rebuild/caliper_rebuild.htm
Old 03-07-2003, 10:29 AM
