Goku's Avatar
Slave replacement
About how much should a slave for a clutch run me at a shop? It's the cluctch to the floor problem. Bleeding didn't help and it doesn't seem to lose fluid? And also is there anything that really SHOULD be done at the same time? Thanks for the info guys
ßrªÐL£µ
88' 951 - Wolf's now :'(
Reluctantly crouched at the starting line...
Old 03-07-2003, 08:17 AM
AFJuvat's Avatar
master and slave should be replaced together
figure about $150 in parts, about 1.5 - 2 hours labor to have it done.
AFJuvata
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-07-2003, 08:34 AM
944pete's Avatar
Yep, replace both. They're both used together and wear at the same rate. If one goes bad the other isn't far behind. Get a pressure bleeder and do it once.
Pete
1989 944S2-Dove Blue Metallic
1985.5 944-Alpine White--sold
My P-car Online Profile
Old 03-07-2003, 08:59 AM
Ornery Bastard
You sure? My car has an intermittant clutch to the floor problem that I've diagnosed as the slave cylinder. Thing is though that the slave and master cylinders were replaced less than 30,000 miles ago. I just can't imagine that they would wear out that fast, my guess was that the slave was defective. Still best to replace both? 30,000 miles on a master cylinder just makes it seem like a waste to replace it.
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 03-07-2003, 09:43 AM
