Slave replacement
About how much should a slave for a clutch run me at a shop? It's the cluctch to the floor problem. Bleeding didn't help and it doesn't seem to lose fluid? And also is there anything that really SHOULD be done at the same time? Thanks for the info guys
master and slave should be replaced together
figure about $150 in parts, about 1.5 - 2 hours labor to have it done. AFJuvata |
Yep, replace both. They're both used together and wear at the same rate. If one goes bad the other isn't far behind. Get a pressure bleeder and do it once.
Aaron |
| All times are GMT -8. The time now is 04:11 PM. |
