-   -   spark plug 'Reading' question (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/101171-spark-plug-reading-question.html)
awilson40 03-08-2003 05:09 AM
Hey gang,
I'm still working on a hesitation issue and have a question. Upon reading my spark plugs, the inner 2 cyl are running leaner than the outer 2. With or without connecting the O2 sensor. The outer 2 plugs are reading richer. I just pulled and flushed the injectors and replaced seals and hats, but the hesitation is still there. I marked and switched injectors, moving the inner 2 to the outer just to see if the problem goes with the injectors. If not , any ideas what would cause the 2 inner to run leaner?
If I connect the O2 sensor then its apparent that the 2 inner cyl are running too lean, which is probably why I have the hesitation.
SoCal Driver 03-08-2003 11:05 AM
You may have a mainfold leak where it bolts to the head.
Dave951M 03-08-2003 03:25 PM
Second the leak, check the manifold bolt torque, if they are the same the problem persists, put on new gaskets and retorque. Make sure the flanges are very clean. Even a small bit of trash can cause irritating problems.
Dave
Frank B 03-08-2003 03:37 PM
Ditto the above motion...
awilson40 03-08-2003 05:05 PM
Thats what I thought also, I retorqued the bolts and pressure tested the intake today with 15psi and sprayed the intake flanges with soapy water. No leaks. The only leak I could find was around the electrical connector on the cycling valve.
