spark plug 'Reading' question
Hey gang,
I'm still working on a hesitation issue and have a question. Upon reading my spark plugs, the inner 2 cyl are running leaner than the outer 2. With or without connecting the O2 sensor. The outer 2 plugs are reading richer. I just pulled and flushed the injectors and replaced seals and hats, but the hesitation is still there. I marked and switched injectors, moving the inner 2 to the outer just to see if the problem goes with the injectors. If not , any ideas what would cause the 2 inner to run leaner?
If I connect the O2 sensor then its apparent that the 2 inner cyl are running too lean, which is probably why I have the hesitation.
1988 951 Alpine White / Burgandy
Profec B spec II EBC,HomeBrew Chips, WideFire HG, Tial 38mm, Magnecor Wires, Koni Rears, Adj Rear Droplinks, Zeitronix WideBand.
Old 03-08-2003, 05:09 AM
SoCal Driver's Avatar
You may have a mainfold leak where it bolts to the head.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-08-2003, 11:05 AM
Dave951M's Avatar
Second the leak, check the manifold bolt torque, if they are the same the problem persists, put on new gaskets and retorque. Make sure the flanges are very clean. Even a small bit of trash can cause irritating problems.
Dave
Dave951M
86 951 Blitzwagen
82 931 Basket Case (for now)
Old 03-08-2003, 03:25 PM
suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
Ditto the above motion...
My car is naughty
Old 03-08-2003, 03:37 PM
Thats what I thought also, I retorqued the bolts and pressure tested the intake today with 15psi and sprayed the intake flanges with soapy water. No leaks. The only leak I could find was around the electrical connector on the cycling valve.
Old 03-08-2003, 05:05 PM
