carolinus's Avatar
Goodbye, Senior Headgasket...
I will miss you terribly.
It looks as if my head gasket has made a hasty departure from this earth. It started out with a slight puff of white smoke after the car warmed up. I was instantly worried that it was coolant, but couldn't really smell any.
Later on, on the way home from work, it turned into a huge cloud of white smoke. Not good. It REALLY smelled like coolant. And the engine is definately missing, now.
I guess I will get the opportunity to change my timing belt early this year. :-). Any suggestions while I am down there? I will have full access to a machine shop and people to teach me how to use it (university shop:-). I am thinking a thourough overhead job while in there.
Thanks!
I am blessed/cursed with these cars:
BMW 318iS 1991
BMW 325iS 1988
Volvo 740 Turbo Wagon 1992
Quote of the week:
"This chemical is known to cause Birth Defects in California."
Poor Californians, they are always getting the short end of it, and now this?
Old 03-10-2003, 06:41 PM
AFJuvat's Avatar
Valve guides, seals, valves and seats checked for spec.
Head surfaced if necessary.
You already did the vacuum hoses, so that should be good to go.
May consider re-sealing the front of the engine while everything is torn apart.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-10-2003, 06:49 PM
I agree with AF - Do all the seals now, it'll save you from having to do them later. Good Luck.
Stay Posted - more to come.
Old 03-11-2003, 06:44 AM
ae1969's Avatar
Send a message via ICQ to ae1969
well at least you know now............
no need to do that compression test to find out what that little puff of white smoke is.....
the only advice I have is take your time while you fix her......dont' rush
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 03-11-2003, 06:52 AM
