-   -   944 S2 Transaxle Part Number (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/101552-944-s2-transaxle-part-number.html)
kev 03-11-2003 04:49 AM
Gents,
I have an '89 944 S2 and the transaxle is one without the limited slip. According to my service manual, the code for the trans without the limited slip for this car is "Type 083F Code AOS". The code for the transaxle with the LS is "Type 083F Code AOT".
I want to put a LS in my car. Who makes this transaxls (Porsche, Getrag, ZF)? Where on the transaxle can I find the part number of the original manufacturer? Does anyone know this part number for the LS transaxle?
Thanks in advance,
Kev
AFJuvat 03-11-2003 06:20 AM
951.332.053.05 is the factory part number
Porsche transmissions are made by ZF.
Pelican sells an aftermarket LSD as well.
AFJuvat
wjk_glynn 03-11-2003 10:32 AM
Somewhat similar question with an answer:
http://www.pca.org/tech/tech_qa_question.asp?id={6DBC7C46-6DB8-4B66-BF95-A00415CCC75E}
Karl.
kev 03-12-2003 09:50 AM
Gents,
After quite a bit of research, the manual transmission on the 944s is made by VW/Audi, not ZF. ZF made the diff and supplied it to VW. ZF made the auto trans for the 944 but not the manual.
Kev
Britwrench 03-12-2003 02:40 PM
The trans is assembled by VW/Audi, the gears and other parts are made by outside suppliers, including ZF.
