Tired Member
VDO 80 psi oil pressure gauge with stock sender?
Does anyone know if the VDO 80 psi oil pressure gauge will work with the early 944 stock sender?
I'm looking at this gauge.
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
Politically Incorrect
That is exactly the same VDO gauge I have in my car with a stock sensor.
Reads around 80 PSI at cold start (at idle) Reads around 35-45 PSI when hot (at idle) depending on ambient temperature. Reads around 60-70 PSI when hot (at speed) depending on ambient temperature. My background and profession is Steam Boilers, so all my gauges (and brain) are calibrated in PSI.
Edek '87 924S '91 535i |
Tired Member
ok, that helps. 5 bar is a little more than 72 psi, so I thought it might work.
