Patrick
Sunroof Screw
I've got another question, while I'm on a roll. My interior sunroof panel is missing the screw found near the rear view mirror. I think the screw is #20 with cap #22. Any ideas where I may locate one or does anyone know the correct size/thread? Thanks!
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
yarfk
------Keith------kfray------yarfk------- 87 944 NA stock 116k 06 Honda Ridgeline 83k 10 Vibe 2.4 AWD (Wife's) Retired My week consist of Saturdays and Sundays
AFM #725
That's so cool, didn't know you could view the diagrams like that. I'm always just typing in the part number and searching.
I have all sorts of interior screws available from the 944 I'm turning into a hot rod. I can send it to you with the cap and washer for $2.50.
Currently have: Guards Red 1987 924S 16v -- Light Blue Metallic 1980 928 Gone: Minerva Blue 1979 928 -- Gray 1985.5 944 -- Black 1989 944 -- Black 1984 944 -- Black 1987 944S -- Alaska Blue 1974 914 1.8 -- Guards Red 1983 944 -- Guards Red 1987 924S -- White 1988 924S -- Maraschino Red 1987 944 Turbo -- Beige 1981 924 -- Red 1984 944 |
AFM #725
^^^ Do you have any extra black interior screw caps? I could use a couple
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Actually all mine are very dark red/burgundy. I'm missing a few black ones myself on my 924S. I think I've seen them here on Pelican Parts, though.
AFM #725
Sigh.. Just hate paying shipping for those two caps that will fit in an envelope
Patrick
Groovy!
Thanks everyone; another step closer to returning her to her former glory. I'll be ordering one tomorrow.
Careful if you are messing around with these screws. Apparently the screws holding the black trapezoidal plate are adjustable and control when the motor stops running when closing. I tightened some things up I thought were loose and now my sunroof is bonkers.
There must be a way to adjust them. |
Patrick
Isn't there only one screw to secure the interior liner to the sunroof panel?
I think I'll post a picture when I have a chance...
Patrick
Here is what I'm talking about; the center hole is obviously missing the mystery screw
In the Fires of Hell.....
I think that you are just missing the cap. That hole contains an adjuster for the front sunroof limit switch.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
The missing screw etc. holds the trim panel in place (items 20, 21, 22 in the diagram).
The other three screws are for the limit switch adjustment. Last edited by djnolan; 05-05-2013 at 12:15 PM.. |
AFM #725
I'm not sure there's a screw there... my old sunroof liner had something missing there and the mint replacement I found just had all the caps IIRC
Patrick
It appears that there should be a screw as the liner droops a bit but looks perfect when I push the liner up. Would anyone know the size thread/pitch? Thanks.
Patrick
PorscheNut924,
If you still have the correct screw, I'm very interested! Please PM me your address and I'll send funds post haste !Patrick
Patrick
Is there anyone who has the screw specs?
Not sure about that,just had mine out for a new seal and trim tidy up,theres no limit stop in there???
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
Sorry to bring this back up but my '84 NA 944 is missing the exact same thing... did you ever figure out what it was?
