Replacing front shocks
I have 944 85.5 with factory KONI oilfilled shock absorbers that have separate parts.
What would be a suitable replacement shock absorber?
And will this be a drop-in replacement?
Looks like this . . .
Old 01-26-2019, 02:55 PM
9FF 9FF is offline
9FF's Avatar
You have a choice of Sachs, Koni or Bilstein inserts, all will simply drop in. Sachs are the same as stock and are the cheapest.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 01-26-2019, 03:43 PM
Thanks, could you give an itemnumber that I could use as a reference for diameter and length between the different brands?
I´m new to this. . . .
Old 01-27-2019, 12:54 AM
9FF 9FF is offline
9FF's Avatar
I must have misunderstood what you said, did you say you want me to look up all the part numbers and dimensions for you?
Just call our host here Pelican, tell them the make, model and year of you car and they will give you item numbers, prices and explain all your options. The phone number is on the top right of this webpage.
Mike A
Old 01-27-2019, 04:39 AM
