83 944 starting problem after intake replacement
Hey folks - need some help here.
Replaced the intake gaskets on the 944 and the car wont start after getting it all back together. It cranks and spits/sputters as if it is trying to start, but will not actually run. Details: -Double checked all vacuum lines and they appear to be routed correctly -Installed a fuel pressure gauge on the fuel rail and I'm getting 37lb during cranking -Pulled fuel rail and all 4 injectors are firing -When pulling the intake off, I noticed the hard plastic connection on the reference sensor wiring (on the little bracket on the back of the intake) was cracked and some wire was exposed. I put it back together with this sensor... wouldn't start, so I replaced the sensor with another and it didn't change the problem at all. Just don't know what to check next. My gut tells me it's related to the reference sensor, but I have no evidence to support that. Could the bare wires on the reference sensor connection have shorted something out somewhere else in the car? thanks everyone, Scot |
Do you have oscilloscope? Concrete measured data plotted on graph will absolutely confirm speed/ref-sensors are perfectly OK, or bad in black/white, yes/no terms.
Looking for one now. thanks
Some basic things to check would be the ICV large vacuum line connection under the intake near the dipstick, and is there tach bounce regarding the sensors and is there spark when cranking and use a noid light to check for injector pulse?
djnolan - thanks for the info. Turned out to the the vacuum line under the intake. Old hose was completely crimped. New hose = starts fine.
| All times are GMT -8. The time now is 06:42 PM. |
