86 944 Antifreeze, lost about 2 quarts
I have lost about 2 quarts of antifreeze.
No leaks under the car.
Pressure tested the cooling system to 15 PSI, it held steady for 20 minutes.
I use Mobil One 10w 30 high mileage and the oil is not clear. it is cloudy.
Can the antifreeze be getting in the oil? The pressure test looks OK.
1) How do you test for water in the oil?
2) Can I use a block sealer the stop the antifreeze from getting in the oil? What brand do I use?
Old 02-02-2019, 07:06 AM
Probably bad oil cooler seals. Park it until you fix it right.
Oil Cooler General Information and Seal Replacement
Good luck, George Beuselinck
Old 02-02-2019, 07:31 AM
Thank you, I will do this.........
Jim
Old 02-02-2019, 07:46 AM
9FF 9FF is offline
9FF's Avatar
+1 it’s likely your oil cooler seals have failed, as part of the the fix you should plan on replacing your rod bearings, it’s just good insurance.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 02-02-2019, 08:06 AM
Hi,
An oil analysis is accurate way to detect coolant mixing with oil. I would send in some oil before starting replacing parts, especially since the oil is not obviously contaminated.
Is the coolant missing after driving the car? Have you looked at the spark plugs? If there is not an external leak, and no leak into the oil, a cylinder head problem is possible.
Good luck,
Peter
Old 02-09-2019, 06:51 AM
Originally Posted by peteb View Post
Hi,
Good luck,
Peter
Thank you, I will check it out........
Old 02-09-2019, 07:22 AM
Carson Guitar
carsonguitar's Avatar
My two bits
Is a heater core leak a possibility causing fluid to drip inside the car under the passenger dash?
Old 02-09-2019, 09:38 PM
