I noticed that my car has yellow Koni shocks, in the front and in rear. The rear shocks have a blue dot mark.
The shocks in the front can be adjusted for ride confort. The car sits really low, so low that it scrapes in low speed humps. Is there any way that I can raise the car an inch or so, with out having to replace the shocks and springs? Thanks
coupe http://www.p-caronline.com/directory/coupe Porsche 944 Turbo, 1986 Fiat Coupe 20v Turbo, 1997 |
Never seen dots on the shocks before, seen them on the front springs - they indicated "stiffness" - one dot being the softest, three being the stiffest.
you will have to check and see if the shocks are adjustable. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
suck my tail pipe
don't tell Cj.. he might have a stroke..
My car is naughty |
Writer/Teacher
i don't THINK they are... but if they are, I will be a happy, happy man
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
If they are yellow konis the front ones should be adjustable under the hood, look for a square section bit sticking up out of the top of the shock, turning this adjusts the stiffness. I have a special koni plastic thing that fits the square section but you could just use a small wrench,
The rears have to be removed to be adjusted. Mark |
Hi there Mark, My shocks are exactly as you say, they can be adjusted for stiffness, I too, have the plastic Koni knob to do it.
But what I wish I could do is raise the car by and inch or so., it is so low, it scrapes on twiggs..
