Interior Console/Feature upgrade
Wanted to know if you all have tried to install the rest of the buttons (options) from Porsche into the center console. Right now mines has three buttons but I see there is room for more.....are these options or add ons to forget about because the original owner never ordered them with the car or can I retro in the factory (options) buttons and make them work of course...how hard would it be or it is not possible to add them in because the original owner never order them. And if this could be done does anybody have a list or can point me in the right direction to find out what those empty slots was meant to be for? Thanks in advance for anyone's help.
Random Console showing all empty slots http://forums.pelicanparts.com/uploa...1551963458.jpg My Car where I have three filled slots and one dummy filler http://forums.pelicanparts.com/uploa...1551963458.jpg |
Of the 6 slots, I've only ever seen 5 of them in use. They are (from left to right) the sunroof switch, rear wiper switch, mirror changeover switch, central locking switch, the blank one and on the far right the speaker fader.
However, one of those slots is also used for the cabriolet top switch on cabs. But if you have a cab, you wouldn't have the rear wiper option so you're still left with only 5 in use. |
Iirc from a previous discussion on here the 6th switch space is used in ROW spec cars for the headlight aim control switch (M605), which I think was mandatory in some Euro countries.
Edit: I just checked in Euro PET and I was correct in recalling it was the headlight aim system. I suppose you could retrofit it if you’re any good with electrical wiring, looks like it’s a simple motor and switch likely wired to a dedicated unused space in the fuse box. http://forums.pelicanparts.com/uploa...1551975116.jpg http://forums.pelicanparts.com/uploa...1551975619.jpg |
Thanks you guys, not sure about the headlight aim control seem too much of a hassle and I already switched to Xenon 7" beams but I might be able to do "22 Fader" is it the fader for the dash controls or.......? Anybody???
The blank spots on the right are so the switches can be moved to the right side for RHD cars, leaving the blank spot(s) on the left side.
http://classiccardb.com/uploads/postfotos/1986-porsche-944-right-hand-drive-7.JPG |
http://forums.pelicanparts.com/uploa...1565170016.jpg http://forums.pelicanparts.com/uploa...1565170016.jpg |
| All times are GMT -8. The time now is 12:48 AM. |
