Interior Console/Feature upgrade
Wanted to know if you all have tried to install the rest of the buttons (options) from Porsche into the center console. Right now mines has three buttons but I see there is room for more.....are these options or add ons to forget about because the original owner never ordered them with the car or can I retro in the factory (options) buttons and make them work of course...how hard would it be or it is not possible to add them in because the original owner never order them. And if this could be done does anybody have a list or can point me in the right direction to find out what those empty slots was meant to be for? Thanks in advance for anyone's help.
Random Console showing all empty slots
My Car where I have three filled slots and one dummy filler
Old 03-07-2019, 04:02 AM
drkshdw's Avatar
Of the 6 slots, I've only ever seen 5 of them in use. They are (from left to right) the sunroof switch, rear wiper switch, mirror changeover switch, central locking switch, the blank one and on the far right the speaker fader.
However, one of those slots is also used for the cabriolet top switch on cabs. But if you have a cab, you wouldn't have the rear wiper option so you're still left with only 5 in use.
Old 03-07-2019, 04:23 AM
9FF 9FF is offline
9FF's Avatar
Iirc from a previous discussion on here the 6th switch space is used in ROW spec cars for the headlight aim control switch (M605), which I think was mandatory in some Euro countries.
Edit: I just checked in Euro PET and I was correct in recalling it was the headlight aim system. I suppose you could retrofit it if you’re any good with electrical wiring, looks like it’s a simple motor and switch likely wired to a dedicated unused space in the fuse box.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 03-07-2019, 06:34 AM
Thanks you guys, not sure about the headlight aim control seem too much of a hassle and I already switched to Xenon 7" beams but I might be able to do "22 Fader" is it the fader for the dash controls or.......? Anybody???
Old 03-07-2019, 03:12 PM
drkshdw's Avatar
#22 is the speaker fader. It's the balance control for the front and rear speakers (moves the sound front and back). I'm pretty sure the wiring is standard so dig behind the console for the plug and plug one in. Certainly easier than adding a headlight aiming system.
Old 03-07-2019, 05:35 PM
Thks for the quick response will see if i can find one for cheap and I will let you all how it turns out.
Old 03-07-2019, 06:29 PM
jhowell371's Avatar
The blank spots on the right are so the switches can be moved to the right side for RHD cars, leaving the blank spot(s) on the left side.
Red 84 w/25,xxx miles
Stone Gray 89 S2 w/90,xxx miles
Old 03-08-2019, 03:48 AM
9FF 9FF is offline
9FF's Avatar
Nope it’s not that but you’d imagine it was. RHD cars had the switches in the same place as LHD cars, also the right most switch location is different to all the others so it cannot be interchanged.
Mike A
Old 03-08-2019, 06:01 AM
jhowell371's Avatar
Beg to differ. Check this picture.
http://classiccardb.com/uploads/postfotos/1986-porsche-944-right-hand-drive-7.JPG
Old 03-08-2019, 08:36 AM
J1NX3D's Avatar
I have one of these leveling switches for sale if anyone is interested. It came off a LHD '94 968 from Japan. $50 USD + postage from NZ to you. They are $130 USD new.
https://www.instagram.com/kiwi944s3/
'86 944S3 conversion
- '94 968 3.0 engine
- 6 spd/LSD
- 17x8,17x9 Oz Racing Crono wheels
Old 08-07-2019, 01:33 AM
