85.1 944 with factory sport suspension: shocks & struts
I have a fairly original early 944 with factory sport suspension. Shocks and struts are needing replacement.
It looks as if the rears are original - I can see yellow under the 35 years of dirt - so it's possible the fronts are original as well. Does it make sense to have these rebuilt? Are these factory "sport" Koni shocks & struts available new? Thanks, Tom |
Koni can rebuild them. That's what I'd do.
Sent from my SM-N950U using Tapatalk |
Check your options code decal, if they are original “sports” versions then you’ll have either M030 or M474 as an option code.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
It's actually the M456 option code (also M220 for LSD).
From my research, the springs are allegedly shorter, so would need shorter shocks/struts(?)... Lots of conflicting information out there on these early sport suspension optioned cars. |
Coeur d'Alene, Idaho
Pardon the bandwidth, but where is the options sheet/sticker on my 84? Thanks in advance.
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback. |
It’s in two places, first page of the service book and attached to the car between the rear tail lights under the hatch carpet.
Thanks. When I replaced the shocks and struts I got the standard OEM type and I'd hate to find out it had a suspension option I should have known about. It's still in winter storage, so I'll find out later....
Thanks Mike - I'll check out True Choice.
I these may be adjustable, but require removal to make adjustments? I won't be sure until I get them out. Tanks again, |
