daveurethane's Avatar
Can anyone tell me how to adjust
Hello, just finished putting everything back together after paint. And for the life of me i cant figure out how to center the headlight buckets and covers . There is about 3/4" on one side of the cover and only about 1/8" on the other side..
Surely there has to be a way to center them so they look better.
Both headlights are in need of fixing
Old 03-31-2019, 03:57 PM
each side has a triangle plate mount thing that the light pivots on.
the triangles each have 3 bolts and oversized holes so you can loosen the bolts a little, adjust the bucket up down side to side as needed and re-tighten.
also the inner triangles can have little shim plates to help center.
Old 03-31-2019, 06:37 PM
Nice paint....did it yourself?
Old 03-31-2019, 06:43 PM
Thanks for the info i will attempt to center them today.
Paint was done by a friend who has a shop out here in cali. But i did most everything in regards to take everything apart and reassemble it all.
Old 04-01-2019, 09:11 AM
Love that paint! Looks like a gray "Hammertone?" If not - what is it?
Old 04-01-2019, 12:22 PM
The paint is gunmetal gray with a silver metalflake , and 7 coats of clear
The paint is from Bayou Innovations
And its there KemFX brand.
Very very good paint i would recommend to anyone who is looking for a good paint.
Although this paint isnt for use in California.
As the VOC content is too high. But if you know the owner of the spray booth and they are far away from the city life then you could spray it. But they are not alowed to ship it to california. So i had it shipped to Arizona and had a friend then ship it to me.
The paint came in a kit with everything and i think it was about $800 for the kit. Including the extra clear.
Old 04-01-2019, 08:51 PM
Here are some close ups of the color
Old 04-01-2019, 09:01 PM
Ok i think i see what you are talking about. But that looks like it will adjust up and down ..
I need to adjust the bucket left to right to get it centered. I loosened the three10mm bolts and no go. Now of i were to shim that i cant see how it would adjust left to right. I have the light cover off but looks like i might have to take the nose panel off no
Old 04-02-2019, 10:13 PM
The picture is showing the 3 bolts correct
img]http://forums.pelicanparts.com/uploads26/image_20190402_2318501554272518.jpg[/img]
Old 04-02-2019, 10:22 PM
All of those gaps look too big. Looks like you might need to start with the hood...move this forward a bit (look at the hinge mechanism, which is adjustable).
Old 04-03-2019, 03:55 AM
Make sure the parts that limit the left to right travel and center the headlight are not cracked or missing.
Old 04-03-2019, 02:42 PM
The paint looks great.
Gone but not forgotten: 1971 914 First Car (SOLD) | 1972 914 rust bucket (SOLD) | 1986 944 Turbo (Murdered by a Chevy Truck on the freeway)
Current lineup: 1990 944 S2 Cabriolet - Long term project | 1971 914 - Long term project #2 | 1971 914 - Driver
Old 04-03-2019, 03:56 PM
The hood is not latched down in pic sorry
Old 04-03-2019, 04:24 PM
I cant see any adjustments in the first pic that would move light and cover left or right. Other then bending the tabs at the mounting for t he cover and plastics
2nd pic is the oversized screw holes for adjusting up and down height
Still at a loss for the left right adjust.
Ps the hood is not latched downn in pic. So it has a big gap in hood and nose part.
Old 04-03-2019, 04:30 PM
Sorry pictures are reversed
Old 04-03-2019, 04:31 PM
I edited your picture to show where the part that limits L/R travel is. If this is not tight and you adjust the headlight it will return to the same spot. Shiming is one way to adjust but this piece needs to be tight so it cant move L/R after adjustment. A pita because you may have to do it from inside the fender well depending on which direction things need to go.
Old 04-04-2019, 02:58 AM
I keep coming back to this post...not to be more helpful (sorry!) but to gaze at that paint! Wow!
Old 04-04-2019, 03:30 AM
