-   -   Testing fans operation (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1035557-testing-fans-operation.html)
morbid 07-24-2019 02:36 PM
When I unplug the thermofan switch and jump the terminals the drivers fan goes in fast speed... Shouldn’t it run in slow speed? What may be the problem here?
9FF 07-24-2019 02:58 PM
There are three terminals: a common ground, a fast speed and a slow speed. You must have it jumped between the fast speed terminal and ground, try jumping the other terminal for slow speed.
morbid 07-24-2019 04:01 PM
Mine’s an 84 944. The thermofan switch has only 2 terminals. According to Clark’s test if those cables are unplug from the thermofan switch and jumped, the drivers fan should run at slow speed. And if the ignition switch is turned on, both fans should run fast.
9FF 07-24-2019 04:58 PM
Gotcha, Im pretty sure that’s normal for the early cars, this may help:
Early Fan Operation - Clarified
morbid 07-24-2019 05:52 PM
Thank you for that link! Now I’m clear. 🙌🏼
