Testing fans operation
When I unplug the thermofan switch and jump the terminals the drivers fan goes in fast speed... Shouldn’t it run in slow speed? What may be the problem here?
1984 Black 944 (w/'83 engine & P/S)
2008 Ford Explorer XLT
Old 07-24-2019, 02:36 PM
9FF 9FF is offline
9FF's Avatar
There are three terminals: a common ground, a fast speed and a slow speed. You must have it jumped between the fast speed terminal and ground, try jumping the other terminal for slow speed.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 07-24-2019, 02:58 PM
Mine’s an 84 944. The thermofan switch has only 2 terminals. According to Clark’s test if those cables are unplug from the thermofan switch and jumped, the drivers fan should run at slow speed. And if the ignition switch is turned on, both fans should run fast.
Old 07-24-2019, 04:01 PM
9FF 9FF is offline
9FF's Avatar
Gotcha, Im pretty sure that’s normal for the early cars, this may help:
Early Fan Operation - Clarified
Mike A
Old 07-24-2019, 04:58 PM
Thank you for that link! Now I’m clear. 🙌🏼
Old 07-24-2019, 05:52 PM
