Head Gasket Test
What is the best way to determine if the head gasket needs to be replaced?
83-944 N/A
Old 03-25-2003, 09:27 AM
perfecto951's Avatar
Send a message via AIM to perfecto951
if you are blowing out white smoke
1986 951, India Red. (Mine) - Not For Sale Anymore
1987 944, Alpine White. (Bother's)
2000 Audi A6 2.7 Biturbo Melange (Mom's)
Old 03-25-2003, 10:25 AM
I have also seen a leaking gasket put products of combustion into the cooling system or put oil into cooling system. If POC go into water, your water system will overpressurize and will vent. Venting will cause more brake dust to cling to the driver's front wheel than the passenger front wheel. It will also cause a loss of water.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 03-25-2003, 10:28 AM
Lawrence, how do you know so much? it baffles my mind - seriously.
Old 03-25-2003, 10:39 AM
Don't know so much. But I have a friend who does DE's with me and has a 944turbo. He would lose water and his left front tire would always get dirtier than the right front. His car braked in a straight line so it did not appear to be a brake problem. His water level would go down. The problem was his head gasket leaking causing venting from the reservoir. The little vent tube directs the coolant near the wheel under the car. The moisture made the brake dust have a greater tendency to cling to the wheel.
Another friend of mine had his 944 head gasket let go big time. It looked like a steam engine. Quite a show.
On the lack of boost stuff, it is my own personal experience.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 03-25-2003, 11:12 AM
Roger Hall's Avatar
Compression, vacum, and leak down tests.
Sypmtoms are:
White smoke from exhaust
Oil in watter
Blown radiator cap.
Cracked expansion tank
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 03-25-2003, 06:07 PM
Pike's Avatar
Location: Redmond WA Can anyone help me with my snorkle mod?
I've never put Watter in my car, where does it go? The fuse box?
'77 924 - Metallic Blue - enlarged TB/ intake
'99 Specialized HardRock - Blue/Silver - Jett C Shocks - Cat Eye Velo computer
If it ain't broken, drive it until something is.
Have you spent quality time with your Engine Gnome lately?
Defend Your Joy
Old 03-27-2003, 05:46 PM
There are also some testers that use a fluid sensitive to Hydrocarbons, it changes from blue to yellow. You place it over the coolant tank and pull some of the steam into the device and if the head gasket is blown even slightly it will start to change color.
A automotive gas analyzer will do the same thing.
88 944s
Turbo front clip
Side markers and rear bumper pads deleted
93 968 interior.
Old 03-27-2003, 06:05 PM
