Steering Rack screw
My power steering fluid been leaking and I just got the re seal kit and took the rack out but I'm having trouble with this one like washer screw thing I dont know what it's called and I used a hammer and punch like you're supposed to but I just cant get it to move or go anywhere and I was wondering if anyone had any advice or experience with this
Old 09-11-2019, 05:39 PM
drkshdw's Avatar
Looks like you may be tightening it instead of loosening it? You need to hit the bottom to make it go lefty loose-y. See the video here:
Old 09-11-2019, 07:13 PM
That jam nut is relatively thin and large diameter and so it easy to get it slightly cocked and jammed up in there when you only strike it on one side. Try alternating your hammer/punch blows from one side of the slot in the nut to the other side to keep it straight in the threads and keep it from wanting to tilt in the hole. And, as the other poster said make sure that you are loosening it, not tightening.
I just did this a few months ago and it seems that you really have to smack that nut to get it to move so keep your strikes balanced. That is what worked for me.
Old 09-11-2019, 10:14 PM
After a bit of hammering I finally got it loose, thank you to both of you I probably would've given up and sold it and bought a new rack without your help lol
Old 09-13-2019, 02:42 PM
drkshdw,
Is the whole procedure for disassembly of the 944 rack on a you tube video? My rack needs to be resealed as well and I was unaware there were kits and I found watching your video instructive, and I am hoping you may have posted the whole thing on you tube or in this forum somewhere. Thank you.
RedMacklin
Old 09-14-2019, 06:47 PM
Originally Posted by Redmacklin View Post
drkshdw,
There are several videos onYoutube on this topic. Here is one.
https://www.youtube.com/watch?v=JM1_UbR11vs
Old 09-15-2019, 04:49 AM
