-   -   <944> Dead Engine Speed Sensor? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/104307-944-dead-engine-speed-sensor.html)
neildeshpande 03-29-2003 04:52 PM
Gruppe:
My 1987 944 NA will crank, but not start. There is no spark (grounded the plug while cranking the engine).
Fuel is fine though I have no checked pressure. New fuel pump and unplugging the rail at the front end indicates there is fuel at the rail under pressure.
I measured the resistance from center to rear-side pin of both sensors. Reference is 940 ohm and speed is 3 mega-ohm. Does that mean the speed sensor is dead? Center to forward pin (ground) is open on both.
Is a used sensor the way to go? The new sensor appears to be around $100.
Thanks in advance!
Neil Deshpande
1987 944 - new fuel pump and filter today along with quarter window installed with the help of instructions from this board!
robm-951 03-30-2003 05:29 AM
I have heard that both sensors should measure out in the 900 ohm range, so I think you have found your problem.
Rob
neildeshpande 03-30-2003 06:05 AM
Rob:
Thanks! I'll order a used sensor tomorrow from Part Heaven.
BTW, what size wheels are those on your car? 18". I'm contemplating a similar purchase for my 87 NA.
Neil Deshpande
