944 addict
a/c compressor install problems
(Also listed in turbo site)
I bought a new Denso compressor for the a/c and verified the part number. After servicing the unit prior to install I started having issues with getting it to fit. I micrometered the mounts and found the mounting ears were 1 mm too wide so I carefully dressed them to snugly fit. Still after two days of effort, I still can't get the bolts to go in. There appeared to be some interference spots at the top so I filed them down and I still can't get the bolts to go in. Am I the only one who has encountered this or is it a common issue with compressor replacement? I've gone over the parts diagrams and pictures and watched videos so I'm still at a loss for where the problem might be.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
Did something on your car perhaps get bent due to hamfisting of the adjustment strut?
I had a car once, non-porsche, where I had to put a blunt point on a pivot bolt and cut a bit of thread into that to draw the accessory mount into alignment via hammer, swearing.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
944 addict
Nope. The old one was pretty tight fitting but it came out. After relieving the new one a tad it would slide in but for some reason it won't let me align the mount holes laterally. I think I'll get back at it with the condenser hose removed (to take the strain off) to see if that will help. It's been pretty hot around here but the weather's cooling finally so I'll give it another try.
Just thinking out loud
You found your answer. Always mount the compressor with the manifold on, then attach the suction and discharge lines/hoses. Did you drain the oil out of the new compressor? Did you measure the oil in the old one?
83 944 91 FJ80 84 Ram Charger (now gone) Last edited by mattdavis11; 11-01-2019 at 10:03 PM.. |
944 addict
I was thinking that very thing. Yes I followed all the proper procedures in readying the new compressor for install, including a new line to the condenser.
944 addict
compressor install SOLVED
Pulled the hose off the compressor, used a mallet to tap the sleeve for the rear mounting bolt back so it didn't interfere with the bracket on the compressor. Finally was able to get it installed and replaced hose from compressor to condenser. That was a head scratcher.
