914ltd
Engine kicks back on starter
I have a low miles 87 base 944. When starting, the engine occasionally fires before TDC like a distributor turned too far advanced. I checked the timing marks on flywheel and camshaft/distributor pulley. They are OK. Thanks in advance!
Brad Mayeur (914 guy) |
If you have the small diameter, gear reduction starter, it generates enough stray magnetism into fooling the flywheel TDC sensor into firing on the compression stroke.
Porsche introduced a new sensor bracket, and a sleeve to combat this problem. The other fix is to replace the starter with one of the older design.
Good luck, George Beuselinck |
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. Last edited by 9FF; 11-21-2019 at 07:47 PM.. |
