-   -   non-working odometer (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/104673-non-working-odometer.html)
Gene Alvarez 04-01-2003 11:02 AM
Does an '86 944 with electronic speedometer sender (as opposed to mechanical cable) still have the famous $40 plastic odometer drive gear? The speedometer now works after replacing the sender, but not the odometer.
Thanks,
will944 04-01-2003 04:00 PM
I have got the same problem with my 87 944! My speedo works, but my odometer has stopped.
Does anyone know what needs to be repaired and how much it would cost???
Roger Hall 04-01-2003 05:01 PM
I never heard of one
Roastin944 04-01-2003 05:05 PM
I dont know much but every broken 944 odometer ive heard of has been fixed with the plastic gear, you can get it on ebay for like 35 bucks. Good luck
John
coupe 04-01-2003 08:31 PM
Have a look on this site.
www.klaindustries.net/
coupe 04-01-2003 08:35 PM
You can get the gear and fix it yourself in a matter of minutes. Look at the tech section at www.klaindustries.net
will944 04-01-2003 10:35 PM
Replacing that gear looks pretty simple. Thanks a lot for your help.
But now my concern is taking off the dash! Maybe I should just have a shop deal with it. I am willing to work on my car....but that seems a bit labor intensive. Is there an easier way of getting at just the cluster????
Will
Patrickprk 04-01-2003 11:24 PM
Odometer access
Will
Don't have a shop do it. You an do this in less than 20minutes to pull the entire cluster out.
First. Remove the steering wheel. Second, Unscrew the three screws with in your vents. You'll find two screws next to the Odometer reset button, and the other one on the right side of your front/center a/c vents.
Third, look at your cluster, look at the clear plastic covering of your instrament cluster, look directly up and you will see three vertical screws that you need to take out. Next, there is a vertical screw on the left side of your blinker and a screw on the right side of yoru windshield wiper switch. Take those out and your complete a/c piece of plastic should just pull out. But be carefull. Next, you will have access to the four screws holding the cluster in -they are very noticeable. (they are on the sides of the cluster)
Then, once you unscrew those, there will be three wiring harnesses attached to the back of your cluster. This is the trick part.
Once you take out the screws attaching the cluster you should be able to pull the cluster out just slightly to obtain view of how the wiring harnesses are attached. Pull all three harnesses off, and then very carefully pull the instrament cluster out.
Once you have the cluster out, there will be a lot of screws that you will have to take out to take the plastic backing off of the cluster. Once you take that out. Refer to the instructions at: http://www.klaindustries.net/ CLICK ON "Technical" at the top of the site and then click on "944 Odometer Gear Instructions."
Hope this helps, hope you could follow me, if you have any more questions feel free to email me.
will944 04-02-2003 07:51 AM
Thanks a lot!!
I'll get to it once all my damn exams and projects are finished!! Damn profs....
