Is the space saver tire functional?
Are these space saver tires still any good given their age?
If I get a flat, should I bother trying to use it or just try to call a tow truck? |
944 addict
There's a procedure for inflating the space saver tire. I'd suggest inflating it per the owner's manual and then taking it to a tire store for inspection. The manual also details deflating and re-storing the wheel in the boot, assuming it's ok.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
I would say no. Rubber that has been in same position for 30+ years, just inflated/unfolded, then gets driven on? Doesn't sound like a great idea.
I think you can still get replacement collapsible spare tires, but they usually are more expensive than a new full size spare. |
If I had a flat locally or in a another town, then I'd call AAA rather than go to all of that trouble. However, if a flat left me stranded in the middle of nowhere, I wouldn't hesitate at all to use it to get back to town. Drive =/< 50 mph on it, it isn't a high speed tire ever. |
I would think the 12v compressor should be tested as well.
I bought a 12v compressor at Sears for a 944 that didn't come with one. I tried to use it to top off the regular tires and it emitted a puff of smoke, but no air... |
good point - the tire is not functional if you can't inflate
I had a flat tire driving my 911SC about four (4) years ago. The Porsche spare in the car is the original spare tire. So, that makes the spare tire approximately 32 years old.
I inflated it and put it on the car and drove home at 30 mph! That said, you must make sure you take good care of them so they can take care of you when you need them. As, Spring44 said above, "spray with silicone spray" before putting it back, since it makes a big difference. So, I guess the answer is: it depends.
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) Last edited by TibetanT; 01-03-2020 at 06:20 PM.. |
