Pagebend's Avatar
1989 944s2 Non-LSD transaxle code AOS
Hello,
I am looking for some input or advise on making my Transaxle code (AOS) to Limited Slip. I have been trying to research this subject and I am not having much luck finding out how feasible this is? Can I install a LSD pack such as Wavetrac, Quaife or Guard without to much of a headache. Is the process of installing an LSD into my Transaxle Code AOS as easy as “Plug and Play” ?
The Transaxle is out and opened up but I wanted to reach out to the Pelican Parts community on how to proceed. Hopefully I can get some valuable input on this topic.
Thank you
Page H. writing from Bend Oregon
Old 01-15-2020, 07:12 AM
In the Fires of Hell.....
kdjones2000's Avatar
Get a shop to install it for you.
You have set preload on the bearings which requires shims to get right, plus the lash on the R&P.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 01-15-2020, 07:40 AM
Dimi 944's Avatar
It is definitely not a plug and play. I service these transaxles and carry parts for them. I have factory LSD units as well. I recommend an experienced mechanic to swap the diff.
Dimi P
Flying Horse Motorsport LLC
flyinghorsemotorsport@gmail.com
Dimi Paralanov
Old 01-15-2020, 08:09 AM
Pagebend's Avatar
Thank you! I will follow your advice.
Old 01-15-2020, 09:11 AM
Pagebend's Avatar
Dimi P
Thank you very much for your advice. I will find a shop that is capable of doing the LSD.
Old 01-15-2020, 09:13 AM
Misunderstood User
Catellus Engineering Catellus Engineering, Inc.
They can do this - highly recommend
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 01-15-2020, 06:15 PM
Tags
limited slip , lsd
