Yet another freakin problem...
Well.... now for some reason the car is running like absolute crap. I started it up tonight and thought that the idle was a little low but started driving it. Anything after about 1/4 throttle, the car backfires, stutters, hesitates and basically loses all power. Once you let off and it is under 1/4 throttle, it revs fine. I found this is more at lower RPM's. Once the engine is reving over about 3-3500 RPM you get get into about 1/2 throttle before it starts acting up. Once home, I got under the hood and you can really hear a hollow bogging sound and the smell of Raw fuel is pretty bad. I am taking it from that that it is spark. WOuld this be the coil? DME? Any ideas?
'83 944
Forest Green
Old 04-09-2003, 09:02 PM
Scott R's Avatar
Check the action and movement of the AFM, sounds like the spring went out and the barn door is not openeing correctly.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-10-2003, 07:23 AM
Just thinking out loud
mattdavis11's Avatar
Have you rinsed the engine compartment lately? Just curious.
91 FJ80
84 Ram Charger (now gone)
Old 04-10-2003, 07:59 AM
One thing I hadn't thought of, thanks Scott, I will check that out.
Matt, nope haven't done any cleaning under there lately.
'83 944
Forest Green
Old 04-10-2003, 08:20 AM
Talked to a mechanic friend of mine and he said that this may be caused from the timing belt skipping a tooth. I replaced the belt about a month ago and it is getting close to retensioning time.
What are your thoughts on this?
'83 944
Forest Green
Old 04-10-2003, 03:02 PM
