RichardBartlett
Placement of the 944S2 Badge
Just spent three hours measuring and double checking the placement of the 944S2 badge for the back of my 1990 944S2, cab.
After researching and looking at pictures and measuring until I was cross-eyed, I learned some facts to pass along. Items needed: Painters tape Rule in millimeters (Ruler in millimeters) Extremely thin bladed flat screwdriver, small 944S2 letters to form the badge Soft towel or cloth 2-3 hours of free time. Letter Height is 18 mm Letter Width is 50 mm The badge (letters) are placed in the vertical center of the Terminal Piece (941 503 627 10) just above the passenger side rear tail light. Dimensions The badge 944S is 223 mm long, 18 mm high, so the bottom of the letters should be 40 mm below the top of the Terminal Piece on the left side and 45 mm from the top on the right side. (The Terminal Piece rises toward the right side of the car) The distance between letters is 7 mm, but the distance to the S is 13 mm from the last 4 in 944. The S is 40 mm left of the junction of the Terminal Piece and the right side section (941 503 626 10) 1. Assemble the needed items on the rear deck of the car, use the soft cloth or towel as a work surface cover. 2. Measure and mark with painters tape the 40 and 45 mm mark from the top of the Terminal Piece, creating a horizontal tape line for reference. 3. DO NOT take off protective covering of the numbers and letters, work with them with the adhesive back covered. 4. Using small pieces of painters tape, tape each number and letter, working from right to left, on the car, bottom of the letters on the top of the tape horizontal line. (S starts 40 mm from the right side section) 5. Here is the time consuming part, back up and look at how the assembled badge will look. Make adjustments until you are satisfied the badge looks horizontal/level and is spaced correctly. 6. Now you can remove the protective backing (white paper) from the back of each letter/number as you use it, keep a small piece of painters tape attached, place each, one at a time and check to see if they follow the horizontal tape line. Hint--the 4's are 18 mm high, so the left side of the 4 needs to be 18 mm from the horizontal tape line. 7. Using the Extremely Thin Bladed Screwdriver, you and carefully pry the letter/number up and adjust as necessary. 8. Now you have the 944S in place. 9. The 2 is placed 13 mm left of the junction between the Terminal Piece and the right side section. It is 4 mm below the S and encroaches about a third of the way under the S. 10. Check for horizontal alignment and attach. 11. Now you can remove the clear plastic protective covering over the letters and numbers, revealing the finished badge. Dimensions - Recap Letter Height 18 mm Letter Width 50 mm Distance between numbers 944 is 7 mm Distance between last 4 and the S is 13 mm Bottom of 944S is 40 mm from the top of the Terminal Piece on the left and 45 mm from the top on the right. Badge (944S) is 223 mm long. The S starts 40 mm from the Terminal Piece and the right side section, working from right to left. Stand back and admire your work!!
Dude, there are medications you can take for that. :lol3
(Nice job) When I did the silver "968" on the back of my Cab, I just eyeballed it. Started with the "6" directly over the keyhole, then did the "9&8". I used Windex on the back to keep the adhesive from really sticking until I had each number just right, then squished them down to clear the excess liquid. (A trick I learned from applying 3 foot long decals/stickers to sailboats in a former life) The 968 script was a little funky because it's an italicized font, but as you describe, you can stand back and look at it and easily see if you've got it just right.
David #476 '78 911SC (gone home to the Fatherland) '92 968 CAB Beck Spyder #201 Too many bikes to list Last edited by dlearl; 10-06-2014 at 12:06 PM.. |
"7. Using the Extremely Thin Bladed Screwdriver, you and carefully pry the letter/number up and adjust as necessary."
Dental floss (non-waxed) soaked in Windex if they get too dry. But generally if you keep just the right amount of wet it will stay put while you adjust, and not stick until you force the excess out. Once again, I learned this technique on 3 foot stickers. Once you master those you can do auto/MC insignia blind drunk in the dark.
David #476 '78 911SC (gone home to the Fatherland) '92 968 CAB Beck Spyder #201 Too many bikes to list |
Richard, I have a Cab. It's been a long time since you did your research, but do you have any pointers on the distance to place the badge above the crease, rather than below the terminal piece?
Also, thanks to dlearl for the Windex trick! |
| Tags |
| 944s2 badge , badge , rear badge |
