-   -   Tips for spark plugs removing & installing ect (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1059918-tips-spark-plugs-removing-installing-ect.html)
Ernie944 05-02-2020 09:00 PM
Here are some tips for removing spark plugs & installing without damaging them,losen them first with ratchet & socket then use a rubber hose to remove & install afterward then tighen to specks.Oil filter shove some paper towels down & around it...will keep it from being messy ,disconect the coil cable ,use filter remover with a long extension & ratchet.Install back by hands.For those who have fancy wheels & nuts & don't want to damage them this socket with with interior softener is the answer.:Dhttp://forums.pelicanparts.com/uploa...1588478115.jpg
http://forums.pelicanparts.com/uploa...1588478152.jpg
http://forums.pelicanparts.com/uploa...1588478218.jpg
http://forums.pelicanparts.com/uploa...1588478262.jpg
http://forums.pelicanparts.com/uploa...1588478285.jpgTake be safe:D
curtisr 05-03-2020 05:23 AM
+1
OK-944 05-03-2020 05:38 AM
Yes...I could see that after loosening a spark plug too much lateral (sideways) pressure could then damage threads - so your suggestion to use a rubber tube to remove them after first loosening and then to install them before final tightening sounds good. Thanks!
jjeffries 05-04-2020 07:10 AM
Thanks Ernie, all these little bits of collective wisdom add-up to make us all smarter.
I'd also suggest a small dab of anti-seize on the plus threads. Some sources recommend against this but in my 30+ years of playing with cars, that's always proved a good idea.
Many of those thirty years were spent playing with Alfa's, which score 10/10 for "Ease of Changing Plugs"
John
CarGuyNeil 05-04-2020 08:50 AM
John
NGK is the only plug manufacturer to recommend no anti-seizure and if you visit their website they have a nice article to tell you why. A special coating on the threads of their spark plugs. Putting anti-seize on will allow the spark plugs to get over-torqued. No other brand that I am aware of has this.
pfarah 05-04-2020 10:06 AM
I don't bother applying anti-seize since the plugs get replaced often (every other year)...
jjeffries 05-04-2020 11:21 AM
Some car MFG’s say no to anti seize on plugs due to a concern about it harming conductivity. I’ll likely never be working on a car that modern.
djnolan 05-04-2020 02:05 PM
One important first step is to use compressed air to blow out any dirt in the plugwell before removing the plug so nothing can fall down inside the cylinder.
Also finish the job with a torque wrench.
Ernie944 10-17-2020 08:54 PM
Reviving an thread of mine ,was thinking it will come handy for new guys which have just join us.Adding a couple pics ,first on notice the rubber acting as softener inside the socket for plugs removal & a wheel wrench I modified from + to T,work real good,both of my Porsche.http://forums.pelicanparts.com/uploa...1602992803.jpghttp://forums.pelicanparts.com/uploa...1602992850.jpg:D
944 Ecology 10-18-2020 04:05 AM
Nice tool. I have found that using only a socket and an extension (no ratchet) to start the plugs in their holes is the best way to ensure that the plug is not cross threaded. Once it reaches the bottom of the hole, I attach the ratchet and give it a snug.
I am a firm believer in antiseize, use it on all my cars, old and new.
Ernie944 10-18-2020 05:42 AM
Agree but found out you get a better feel with the rubber hose when it come to start them up,BTW lot pf guys forget to replace this little fellaw when doing their oil change ...The oil drain plug washer... cost $0.25http://forums.pelicanparts.com/uploa...1603024655.jpgNot sure if they come in two dimension ,the one on my 944 was 22x27x1.5 mm can you shed some ligth on that George.:D
Ernie944 10-18-2020 07:01 AM
Will keep on going with more infos,not for the old timer but the new members,hate to call them Newbie or Green:http://forums.pelicanparts.com/support/smileys/wat3.gifThe two next pics will show you the rigth level to have on your oil dipstic....http://forums.pelicanparts.com/uploa...1603029175.jpgBleu straw full....red don't start your motor unless you add oil. http://forums.pelicanparts'com/uploa...1603029328.jpgsecond pic Black mark your ok to drive but should top off.
Ernie944 10-18-2020 07:02 AM
http://forums.pelicanparts.com/uploa...1603029725.jpg
:eek:can happen to the best:D
944 S2 10-19-2020 11:57 AM
Great tips!
Now if only we could figure out how not to dump oil all over the place when removing the filter!
Ernie944 10-19-2020 01:45 PM
Originally Posted by 944 S2 (Post 11070197)
Great tips!
Easy it's in the tip ,lot of paper towels around the bottom & once losse flip it up fast ,this way you migth have oil residu but it will be minimum.Work for me it should for you. Let me know if you suceed.:D
Datsom 10-19-2020 05:28 PM
Awesome info, @Ernie944. Will definitely use the rubber hose tip for the Porsche plug change. Keep'em coming.
@Jjefferies is absolutely right about Alfas -- doesn't get any easier on those beautiful engines... except trying to find a source for the recommended Golden Lodge spark plugs is a massive challenge. The Alfa guys will know what I'm talking about! :)
PHillary 10-21-2020 09:38 PM
+1 on this also you can turn a plastic shopping bag inside out put your hand in it like a glove then finish unscrewing the filter and quickly flip it up into the bag for a less mess easy disposal...easy peasy!!!
mytrplseven 10-27-2020 03:19 PM
Does anyone make an adapter for a remote oil filter?
Ernie944 10-27-2020 04:24 PM
Give Linsay Racing a try.:D
