Patrick
Bolt Torque Request
Hey All,
I'm looking for the bolt torque for these four bracket to engine block bolts. I can't seem to find the values... Thanks!
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
From workshop manual volume 1 page 10-04
Engine supports left + right to crankcase M10 48 Nm (35 lb ft)
Good luck, George Beuselinck |
Patrick
Good Morning George,
Thanks for responding. The engine support to crankcase bolts are actually right next door to the ac bracket (red arrow points to one of the support to motor mount bolts), albeit having what appears to be the same size bolt pattern. It was the closest description I could find of a similar-sized bolt going into the block and, just by pure dumb luck, 35 ft/lbs was the value I estimated and used.
How about this one?
volume 1 page 10-05 Console for generator to crankcase M10 45 (33) Of course, you have to be old like me to remember when cars had generators instead of alternators.
Good luck, George Beuselinck Last edited by 944 Ecology; 05-14-2020 at 04:33 AM.. |
Patrick
That's it! Thanks. I'm hoping to receive a new steering shaft today and get her back together by the weekend.
Patrick
