-   -   Driver side low beam Headlamp issues (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1068585-driver-side-low-beam-headlamp-issues.html)
TiggerTheMighty 07-27-2020 08:59 PM
I replaced the lamp with a new one and the issue persists. I get bright lights for both driver and passenger but I only have passenger side low beams.
Fuses look good and I dont see how it could be an issue with the relay. Contact points look clean but I scraped with a razor to be sure. Any suggestions would be greatly appreciated.
mytrplseven 07-28-2020 01:08 PM
I'd check the ground connection to the body/frame. It's in the area near the a/c dryer, behind the driver's side headlight.
pfarah 07-28-2020 04:05 PM
Or, in my case, the culprit was the connector pin behind the relay/fuse board.
