Driver side low beam Headlamp issues
I replaced the lamp with a new one and the issue persists. I get bright lights for both driver and passenger but I only have passenger side low beams.
Fuses look good and I dont see how it could be an issue with the relay. Contact points look clean but I scraped with a razor to be sure. Any suggestions would be greatly appreciated.
Old 07-27-2020, 08:59 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
I'd check the ground connection to the body/frame. It's in the area near the a/c dryer, behind the driver's side headlight.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 07-28-2020, 01:08 PM
Patrick
pfarah's Avatar
Or, in my case, the culprit was the connector pin behind the relay/fuse board.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 07-28-2020, 04:05 PM
