![]() ![]() ![]() Could someone tell me the part number for the bolt labeled as "D" in this picture is? Credit for the picture goes to the user ernie9944 |
It’s 944-424-147-00 and you can buy it online from Sonnen or any other Porsche dealership who sells online.
Btw you can look up any part number in the PET parts catalog on Porsche.com, your item is #28 on page 217. ![]()
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
Remove nut 30 to remove the bolt and everything else attached to it. No grinder necessary.
Good luck, George Beuselinck |
Replace it with this:
https://www.only944.com/partscatalog/only/shiftlinkagearm/ include this to improve your shifter feel: https://www.only944.com/partscatalog/only/shortshifter/
Gone but not forgotten: 1971 914 First Car (SOLD) | 1972 914 rust bucket (SOLD) | 1986 944 Turbo (Murdered by a Chevy Truck on the freeway) Current lineup: 1990 944 S2 Cabriolet - Long term project | 1971 914 - Long term project #2 | 1971 914 - Driver |
That won’t do it, the inserts in 28 will stop the bolt 29 coming out which is the issue the op is asking about.
Soak it in boiling water.
Curious have you tried this?
You know it’s made of hard plastic not rubber.
https://support.cessna.com/custsupt/contacts/pubs/ourpdf.pdf?as_id=17564 |
That’s good to know thanks. I shall have to try that next time.
Dan,
Just in case you hadn't thought of this: When you need a special part that is $$$$ from the dealer, used parts can be your friend. So a call/email to Plyhammer Parts or John Graves (google justjoshin' porsche) can bail you out of an otherwise expensive problem. Even if they charge (the customary) 50% of new, you're still ahead. Best of luck to you, John
82 911SC coupe |
Northern Motorhead
Dan,
I would second what AZ mentions about only944 shifter bits ... not only are their products a major improvement to a 40 year old design but Kyle stands by his products 100%. I had the bolt "B" become loose in the threads after six years of use on my race car and Kyle graciously sent me a complete newer ( updated ) unit free of charge.Not many people stand by their products like that these days ... Cheers Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
I installed mine out of the car and it was extremely simple. The toughest part will be taking out and putting in the replacement for 28-A in the previously posted diagram. It should not be too hard.
Thread Tools | |
Rate This Thread | |
Tags |
help me , part number , shift linkage |
