-   -   1987, 944s running lean. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1077492-1987-944s-running-lean.html)
E's(87)944s 11-06-2020 07:14 AM
What's up, I have an 87 944s and I'm having a couple of issues. When I bought the car I didn't know it had several different injectors in it... it actually had one injector for a turbo model and one for a 928. The wrong injectors caused a misfire, So I've now replaced them with remanufactured genuine Porsche injectors. However, the car is now running lean. I've put sea-foam through it once to try and clean all of the old gunk out. after I did that I inspected the injector wires and I've replaced them all. the car runs and drives with no problem but it is definitely running lean. I replaced the coil, and the cap and rotor and the wires. The only three things I can think of that would cause the car to run lean are, a.) timing, b.) o2 sensor, and c.) the DME?
944 Ecology 11-06-2020 09:52 AM
What is your fuel pressure reading?
If good, then your coolant temp sensor might be bad. Maybe a bad ECU.
Fast Freddy 944 11-06-2020 06:09 PM
Have a porsche dealer check it out, the can do a diagnostic on it and see whats up..
kdjones2000 11-06-2020 06:20 PM
Vacuum leak?
v2rocket_aka944 11-07-2020 03:30 AM
how are you so sure it is running lean?
do you have a wideband O2 hooked up, or is it failing smog?
