-   -   Only944 LED Headlight Kit (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1077790-only944-led-headlight-kit.html)
Rocket944 11-13-2020 11:53 AM
Only944.com LED's
Did the headlight swap last week...easy and huge improvement over original sealed beams. Both low and high beam work well if properly directed. Was not blinding on-coming drivers and visibility was greatly improved.
mazdaverx7 11-14-2020 04:14 AM
Also was wondering what the bulbs looked like installed. Its great to hear that the kit is a good improvement over the original units without costing a fortune.
idaho944 11-14-2020 09:28 AM
Put the lights through their paces last night, driving across most of Colorado and Kansas on our way across the country. They continued to work well and didn’t cause any eye strain for us because of the color.
The low beams have more light in the peripherals and the high beams are directed more narrow and further forward. Pics of high and low beams below:
http://forums.pelicanparts.com/uploa...1605374798.jpg
idaho944 11-14-2020 09:30 AM
And Madeverx7, they look very similar to the originals, just a big round piece of glass of a slightly cooler color (slightly less orange). If that answers your question?
9FF 11-14-2020 12:42 PM
The low beams have more light in the peripherals and the high beams are directed more narrow and further forward....
Finally, an LED option that doesn’t put out patches of light, color looks good and it has a clear cut-off. All the others I’ve seen on 944’s are brighter but everything else about them was bad. Good job Kyle!
http://forums.pelicanparts.com/uploa...1605386515.jpg
mazdaverx7 11-15-2020 05:10 PM
Based on the pictures and your review, I will definitely be ordering a set! These are exactly what the car needs as the original headlights are very dim. Thank you very much for following up!
mazdaverx7 11-28-2020 04:02 AM
I went ahead and ordered a set from Kyle based on these pictures and your review. I think they will be an amazing upgrade!
Peter Graham 11-28-2020 08:29 AM
Just preordered two sets: one set for the 944 turbo, one set for the 68 912 SWT!
Peter
OK-944 11-28-2020 09:28 AM
These lights look great...but jeeesh! - my "to order" list of stuff from Kyle keeps getting longer!
mazdaverx7 11-28-2020 09:38 AM
Now is the time to order as Kyle is running his black Friday 10% off storewide sale! I think it only runs until the 30th!
mikepellegrini 11-30-2020 08:28 PM
Originally Posted by idaho944 (Post 11098307)
Also excuse the messed lower bumper. You should've seen the other guy (it was a very sad encounter with a coyote last summer). Does anyone know about pulling these off and rebuilding them with epoxy/fiberglass? I've done some work on boats so I'm inclined to think it's possible.
I would take it off and then see if you can bend it back into shape - setting heavy objects on it/clamping it. Maybe with a little heat (heatgun).
If you can bend it/press it back into shape, you can fiberglass a metal support to the underside. I've done that before on mine (on the center, horizontal crossbar) and it worked well.
Is the vertical support in the center torn off from the bottom panel? That would have to be fixed back in place.
The valence is pretty soft plastic. It's not hard to work with.
jjeffries 12-01-2020 04:40 AM
.... in addition to Mr. Pellegrini’s excellent advice, I’d urge you to look for the right adhesive(s), something professional, mail ordered or from local auto body supply house. 3M, SEM et al make such products. And, it’s wise to use splints or other supports that remain after the repair ... OK if no one can see them and they don’t interfere with anything else.
Best of luck, John
Peter Graham 01-05-2021 12:57 PM
Shipped 22 December, USPS finally delivered these today!!
Question for those who have installed them: how did you manage to install the rubber dust boot?
Without the boot, the Cibié Z-Beams go back in...
TIA,
Peter
Rocket944 01-05-2021 01:23 PM
Snow at night...not good.
I did recently encounter a situation where these very clear and bright replacement headlights were an issue...at night, in reasonably heavy snow. They lit up the falling snow to the point where driving was dangerous because I could not see anything beyond the falling snow. I had not planned to drive in these conditions, and I was able to pull off the road to let the snow squall pass, but will certainly avoid going forward.
Peter Graham 01-05-2021 03:24 PM
Wow! Installed: <almost> too much dispersion above low beam cutoff, especially from the passenger side. Removed the headlight and the bulb was loose (and was twisted) from its base, causing a light 'leg' up in the air.
Question on how to install boot solved: twist base from bulb about 20° until dimples in base align with grooves in bulb, remove base.
Next problem: base is no longer fits tight to the bulb... peen dimples in base a little deeper (gently as base metal is very soft). May need to mechanically bind (read: 'glue') base to bulb after boot install (turn boot inside out for installation into headlight, then back to complete dust/water protection).
http://forums.pelicanparts.com/uploa...1609888991.jpg
Jury still out on this one...
Peter
mazdaverx7 01-06-2021 04:00 AM
I installed mine last week and I did not use the boot.
Spring44 01-10-2021 11:54 AM
I received my kit yesterday and have put the lights and boots together without any problem. It is raining and so I haven't put them in the car yet.
My question is about the orientation of the bulb inside of the headlight unit. Do the yellow LED strips in the bulb face up and down inside of the headlight unit or to the right and left, or does it make any difference? It would be nice to be sure about this before putting them in the car.
edit: I did a little research online on this topic and the bulbs like ours with one LED strip on either side of a flat plate should be oriented with the LED's facing in the nine o'clock and three o'clock position.
TheSecondChris 01-10-2021 02:17 PM
This bulletin board is great but you could also email Kyle at only944. He always responds to me when I write with questions.
