-   -   Speed sensor connector (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1081542-speed-sensor-connector.html)
massive 12-23-2020 10:57 AM
Anyone know if its possible to just replace the connector on a speed sensor lead?
Mine has broken and works it way loose from the other connection point. Nothing is wrong with speed sensor end of the lead itself.
tims944 12-23-2020 07:16 PM
Yes they make and you can buy replacement female or male side connectors.
massive 12-24-2020 01:19 AM
Do you know what they are called or what the part number may be?
9FF 12-24-2020 03:45 AM
You can ask our host here, I believe 022906233B is the item you are looking for and it seems they have it in stock. Or you can buy a complete repair kit from 944 Online.
Jfrahm 12-24-2020 04:31 AM
I've used a cheapo volvo sensor to get a connector like this, have to splice it on though. $8 or so for a Volvo 240 one.
Sirlapsalot 12-24-2020 06:41 AM
Wow that 944Online kit is quite over priced...
https://www.milspecwiring.com/BOSCH-LK-3M-CONNECTOR-KIT_p_888.html
https://www.milspecwiring.com/BOSCH-LK-3-CONNECTOR-KIT_p_560.html
If you just need the harness side, not the sensor side:
https://prowireusa.com/p-3901-bosch-style-3-way-kit-with-straight-boot.aspx
massive 12-24-2020 08:00 AM
It's the male side on mine that has broken. I think I've found this item on ebay, which seems to have both male and female side for a reasonable amount
https://www.ebay.co.uk/itm/3-Way-Pin-Female-Male-Automotive-For-Bosch-EV1-Electrical-Wire-Connector-Plug-UK/184498024658?epid=13041865491&hash=item2af4f070d2: g:Z5EAAOSwCFFfrexG
