944 addict
plain rotors vs cross drilled
I know that all performance cars seem to use cross drilled rotors with "performance" pads but I'm asking, "for a street car with occasional autocross stints, are plain rotors more effective with stock pads"? (also posted on Rennlist).
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
I don't have data on hand to back it up but yes, I think plain rotors are more effective than drilled. You'll never see them on a race car as they don't handle repeated heat cycles well without warping or cracking between the holes.
Bottom line, you won't see any noticeable performance difference on a street car or the occasional autoX. If you really need to boost braking performance, you have to go bigger. |
Cross drilled crack often and that bothers me a lot. I prefer plain or slotted.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
More than likely, your brakes will never get hot enough at an autocross to benefit from cross drilled rotors. In fact "cold brake" characteristics can come into play and be more important, especially if you are the only driver and wait time between runs is long.
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
Banned
Drilled rotors are a pain, and completely unnecessary in your application.
... but they look cool!
Just kidding. John |
What about these ?Anyone here has experience with them?
Caraquet,N.B. Canada. |
Every time I see a street-driven drilled rotor, the wear profile is terrible. Grooved, wavy, etc, and must feel awful. Can't imagine the pads fare much better.
That said, I think they're not drilled for heat reasons (better to have more thermal mass than less), but rather pad degassing. Drilled rotors will provide immediate bite in a wet/cool situation where your solids may need a moment to "wake up"...
'84 944 5MT / '89 ANDIAL 951 / '92 MX-3 GS 5MT Projects: '82 928 5MT / '85 944 5MT / '92 740 Turbo Wagon |
Kessel run in 12 parsecs!
Drilled rotors dont work on everyday vehicles, the one that is driven in traffic and crappy weather. They work best in racing conditions and nothing else. One might get some miles on the cross drilled, and the performance will probably be slightly noticable, but they can and will crack rendering vehicles unsafe. For day to day driving, stick with non-drilled smooth rotors.
Getting old sucks, bring back the good old days, this new stuff is for the birds.. |
944 addict
This question was a follow-on search trying find out why my braking action is not as good as it should be. I figured that if the boffins at Porsche chose plain rotors with decent pads, it was the proper combination. You guys have reinforced my supposition that my cross drilled zimmerman rotors with Hawk hi-perf pads may be my undoing. they do look cool though.
Take Ernie's advice:
1. make sure your calipers are working properly and not leaking. When installing the pads, check that they move freely by hand with no binding 2. do the stainless brake lines at all four corners. I can also attest that this brought me a nice gain in pedal feel and brake response. |
These are for a Turbo Ssssss
928.351.044.60SL Brake Rotor - Front Right - Slotted - Brand: Sebro $164.71 928.351.043.60SL Brake Rotor - Front Left Slotted - Brand: Sebro $164.71 Mike G. |
Northern Motorhead
I had bought some custom slotted rotors from LC Motorsports a few years back for my race car.Not sure if they're still in business , but they were operating out of Phoenix NY at the time.
Basically he takes whatever rotor your car uses and has them slotted , the workmanship was top quality and the turnaround time was quick.With the currency exchange and cost of shipping to Canada these days , i just use regular rotors for the race car , along with adequate cooling ducts and i have no issues.My 89 911 has 996TT brakes ( upgrade ) and i find the Sebro slotted rotors outlasted the drilled Zimmermans that came with the brake kit. A properly functioning stock 944 brake system is more than adequate for a 944 !
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 Last edited by wildcat077; 01-16-2021 at 10:01 PM.. |
