Dash indicator lights, what do they mean??
I have the 1986 944 NA new to me by about 6 months. There are two indicator lights I have no idea what they are indicating. One is orange shaped like a diamond and comes on and off with acceleration and deceleration. I assume a vacuum indicator but what for?? There is already a MPG indicator gauge. The other is at the top of the dash between the speedo and tach, rectangular and red with an exclamation point in the center. I only see it illuminate when the lights are on at night. When I am coming to a stop it will be dimly lit and then will get brighter for some reason. Foot on or off the brake doesn't seem to matter. I don't want to ignore it if it's a critical indicator.
Thanks,
John
John
1986 944 NA Black on Black
1966 Cobra Roadster Replica Silver no stripes
Old 01-17-2021, 12:15 PM
not familiar with the up shift light but i would check your batteries static charge and alt output.. (a loose belt would squeal a bit at start up trying to bring the battery back up.)
Old 01-17-2021, 02:10 PM
Patrick
pfarah's Avatar
Hey John,
That orange lamp is your upshift indicator - it comes on to let you know when to shift to the next higher gear for best fuel efficiency.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 01-18-2021, 04:47 AM
Patrick
pfarah's Avatar
Taken from the 1987 Owners Manual:
Old 01-18-2021, 04:58 AM
Thanks for the explanation. Ill pay more attention to it now that I know what its telling me.
Any help on this one??
"The other is at the top of the dash between the speedo and tach, rectangular and red with an exclamation point in the center. I only see it illuminate when the lights are on at night. When I am coming to a stop it will be dimly lit and then will get brighter for some reason. Foot on or off the brake doesn't seem to matter. I don't want to ignore it if it's a critical indicator."
John
John
Old 01-18-2021, 11:10 AM
Ernie944's Avatar
Thanks,
John
John...this is a 968 Dash pod when you turn the key on...see first pic,some ligths migth be different then yours but grosso modo some should be the same, as you can see the exclamation ligth will come on when you turn the key,but after the car is started all ligths should go out,if the,,, exc ligth...don't go off there is something faulty in the systeme,The problem is it coukld be almost anything,from the alternator not charging rigth to brakes sensors ect ect .There is peoples on this forum which will be able to help you sorting it out ,please help this fellaws out guys.
Key turn on but car not running.
Car running ligths all off.
Caraquet,N.B. Canada.
Old 01-18-2021, 01:57 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Check to see if the light goes out as you increase the idle a few hundred rpm. If so, either set the rpm higher or check the Alternator for proper output. Does the battery check out?
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 01-18-2021, 05:01 PM
Good question...I only notice it when its dark and the lights are on. Nothing in the daytime when the lights are off. Idle is at 1K and the battery is charged. It could be possible the lights are putting the extra load on that is causing the warning. I will check the output next time i'm in the car. Currently its at the spa getting some cosmetic paint and body work. I may not see it for a couple weeks. Thanks all for the information. I'm slowly getting educated here. The forum is a big help!!
Thanks,
John
John
Old 01-19-2021, 05:58 PM
Thanks,
John
Congratulations!!! and Welcome to the forum...Post some pictures of it when you get it back.
Old 01-21-2021, 05:57 PM
