-   -   Air recirculate button stuck (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1084346-air-recirculate-button-stuck.html)
Kiwi944 01-25-2021 08:25 PM
The air recirculation button on my non a/c 85.5 is stuck in the "in" position, which I assume is full recirculate - so no fresh air coming in. Is there any way to remove the switch from the heater control panel and attempt to free it?
944 Ecology 01-26-2021 06:12 AM
Nope. It would be easier to remove/manually open the flap that closes the air intake under the hood.
kdjones2000 01-26-2021 07:01 AM
The switch would need to be desoldered from the unit, after tearing it apart.
I would try a touch of silicone spray on it and see if that loosens it up...
